intake manifold does any one have an after market one
Old Nov 29, 2007 | 07:36 PM
Nissan98's Avatar
Yea i was looking for an aftermarket intake manifold.
I was wondering how much hp i would gain?
Where to get one?
and how much they cost?
Thanxs
Old Nov 29, 2007 | 07:41 PM
96blkonblkse's Avatar
Search and you will find all your answers, but in case you were wondering you mean like this
Nissan98's Avatar
Yea im trying to find one like that where did u get it
Old Nov 29, 2007 | 07:44 PM
You can buy them from courtesy nissan there site is www.courtesyparts.com
The other better alternative is the 00vi from the 00-01 maximas. It is a much more difficult swap compared to the MEVI which is what i have. The mevi is basically a bolt on, but will require an RPM switch, vacuum canister, control solenoid and perhaps a check valve if your vacuum canister doesnt have one. It is a somewhat involved job, you will have to remove your intake plenum and everything before it.
The 00vi requires you to use either the 00-01 LIM + injectors, and the 00-01 UIM, or 4th gen LIM which needs to be redrilled so you can use the 00-01 UIM. Then you will need to decide if you want to use the 4th gen TB and IACV, or go with the 5th gen unit.
Search my freind there are TONS of more informative posts the mine!
Old Nov 29, 2007 | 07:52 PM
Nissan98's Avatar
ok thanks that gives me alot of information on what i have to do
maxx0831's Avatar
damn dat set up looks hot, how much HP do u get ever since u got that?
Old Nov 29, 2007 | 08:04 PM
KRRZ350's Avatar
Does nobody read the stickies anymore?
Nissan98's Avatar
one more question for you how long did it take for you to install and was it kind of easy.
Also about how much HP did u gain
Old Nov 29, 2007 | 08:09 PM
maxx0831's Avatar
just looked at the stickies, doesnt look easy to me but if anyone wants to take a look here it is
http://www.vqpower.com/v2/readarticle.php?article_id=50
Old Nov 29, 2007 | 08:15 PM
pmohr's Avatar
No more Maximas...
Search or read the stickies, you can learn a lot.
Old Nov 29, 2007 | 08:46 PM
black_maxed95's Avatar
if you are looking for hp gains there is a great dyno thread in the all motor stickies. compares the mevi vs 00vi vs usim. shows 00vi is the best.
Old Nov 29, 2007 | 08:56 PM
XAugusta MoonX's Avatar
Well.... since you don't seem to know much about modding... I wouldn't try either, but if you're going to- 00VI all the way.
Old Nov 29, 2007 | 09:52 PM
Yeah the MEVI is fairly straight forward, but there are a lot of little things that can get you, especially the wiring for the control solenoid, rpm switch and for the rpm input signal. If you havent done anything major like that before and your mechanical skills are average or below average, as in your set of tools consist of a crecent wrench and a hadn ful of screw drivers i would NOT even attempt to do it. My dad was a ticketed mechanic, i am an apprentice and it still took me 3-4 hours to do the MEVI install plus both my valve covers. figure this i didnt even get my mevi working for 2-3 weeks because of the stupid actuator.
Old Nov 29, 2007 | 11:24 PM
maxpeed96plat.'s Avatar
http://forums.maxima.org/showthread.php?t=542561
Old Nov 30, 2007 | 06:17 AM
Flava_24/7's Avatar
Boosted Panda
A modded ECU with the extended rev limiter is also needed. Without it the extended rev limit there really is no reason to do the MEVI.
Old Nov 30, 2007 | 09:02 AM
grey99max's Avatar
LandShark has Cosworth
Well, that's one opinion. My ECU is stock. With my MEVI, the power curve extended upwards until fuel-cut at 6650.
Old Nov 30, 2007 | 09:24 AM
Flava_24/7's Avatar
Boosted Panda
Really, Dyno graph to go with that? That was all motor right? When I dynoed without it I definately saw a difference, it basicly steadied out and right at 6500 it dropped instantly. With the JWT it kept climbing all the way up to 7k
Old Nov 30, 2007 | 10:32 AM
grey99max's Avatar
Yeah, I've been on dynos using the previous 3.0s - with the MEVI installed. Without it, your power curve would drop off quickly after 5000, based on others' NA dyno with USIM.
With it, at least in my experience, the power went on up to OEM fuel-cut - short intake ram and 3" Warpspeed exhaust. With spray, it went UP until I hit fuel-cut/nitrous-cut programmed at 6500. I also have a custom-build electronic MEVI controller using some relays and a MSD 8969 RPM switch. Dead reliable, but it had to be set to 4800 so that the butterflies would flip at 5000 - with 150-shot at launch, you get through first gear quickly, and the mechanical delay needs some compensation in set point. In the higher gears, no such problem...
The MEVI and controller is now surplus since installing my cammed 3.5. Can't wait to dyno this one.
Old Nov 30, 2007 | 01:56 PM
t6378tp's Avatar
Turbo 3.5
so is that alitte do hicky arm thingy for sale , I have been thinking about getting rid of the vac can
Old Nov 30, 2007 | 07:03 PM
deadmax96's Avatar
interesting....yes yes
Old Dec 1, 2007 | 07:35 PM
grey99max's Avatar
Sorry - when I decide to sell all the 3.0 stuff, I'll offer the ported MEVI with the custom controller and unused cover plate together. Probably in the spring, unless you want to buy the whole package?
I gave the wiring diagram to streetz, along with where I got the door-lock solenoid. Interested?
Old Dec 2, 2007 | 05:31 AM
t6378tp's Avatar
Turbo 3.5
naw not looking to get the whole thing, but know a few guys who would like to get their hands on it
yes, I would like the wiring diagram
Old Dec 2, 2007 | 06:08 PM
grey99max's Avatar
Here's a down payment - a few links..
http://i48.photobucket.com/albums/f2...r/Dscn2334.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2333.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2332.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2331.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2330.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2328.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2323.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2322.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2321.jpg
Wiring diagram X3
http://i48.photobucket.com/albums/f2...r/Dscn2337.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2338.jpg
http://i48.photobucket.com/albums/f2...r/Dscn2339.jpg
door lock motor like these:
http://cgi.ebay.com/ebaymotors/Door-...spagenameZWDVW
Old Dec 2, 2007 | 06:56 PM
markd248's Avatar
What's that?
Old Dec 2, 2007 | 06:58 PM
MaximaSpd85's Avatar
please excuse my noobiness, but what is the benefit of that over the way the MEVI actuates already?
Old Dec 2, 2007 | 07:25 PM
a rats nest of wires
Old Dec 2, 2007 | 08:17 PM
grey99max's Avatar
Unlike using vacuum to move the butterflies, this design uses a MSD 8969 rpm switch and some electronics to control a door-lock solenoid which flips the butterflies - quickly, completely, and reliably - big assets when you spend a lot of time on the drag strip. Most useful on heavily modified engines....
Old Dec 2, 2007 | 08:21 PM
despite my "rats nest" reply i really do think its a good idea and agree it would be much more reliable than a vacuum system and seems like it would be better.
Old Dec 2, 2007 | 08:22 PM
now is there some kind of proof or did someone have a problem with the butterflies not opening quickly, completely, and reliably?? just wondering...mine seem to open everytime at the same exact time pretty quickly. is it something im not seeing?
Old Dec 2, 2007 | 09:22 PM
grey99max's Avatar
Yeah, I've heard the usual yatty-yat about the wiring, starting with Maxus 2005 - but what you see is what happens when you leave all the dual-stage NX solenoid wires, relay wires, and power buss wires at full length. They are all connectorized, and perfectly legal. Just long.
If you've been through as many track tech inspections as I have, you too would think of ways to distract the tech inspectors from looking too hard. Hang a few distractions in front of them and they don't ask you to pull lug nuts to check the depth of thread engaged by the nut. Leave your helmet and fire jacket on the passenger seat so that they want to check certification dates. Make sure you polish your front axle nuts with a wire brush and spray w/PB Blaster so the axles look almost new, and be sure the hub covers are removed before tech. Be sure you take your laptop out of the car - leaving that in the front seat will get you tossed out now. NHRA regs are tight - at real tracks...
Making sure your MEVI switches every time, all the way, is another step toward winning - and "success is in the details".
If you just drive the streets with your MEVI, then vacuum doesn't matter....
Old Dec 2, 2007 | 09:51 PM
ajcool2's Avatar
I got my intake manifold from the junkyard.
Old Dec 2, 2007 | 10:58 PM
t6378tp's Avatar
Turbo 3.5
thanks
Old Dec 3, 2007 | 08:00 AM
kzoosho's Avatar
wow that almost looks like my project car
Old Dec 3, 2007 | 12:36 PM
grey99max's Avatar
Things change - this is my project now:
Old Dec 3, 2007 | 01:49 PM
ROCKART's Avatar
wants an I35
it doesnt matter that ur MAF is tilted like that?
i read it had to be flat and parallel with the ground
Old Dec 3, 2007 | 02:05 PM
grey99max's Avatar
It's flat (level) - if you look at it from the side. And it doesn't make a difference, IMHO.
aw11power
Oct 10, 2021 04:57 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
