smoke from engine
smoke from engine
I have smoke/steam coming out the back side of my engine when it's hot. Smells like engine oil.
I can't really tell where it's coming from. Could this be the valve cover gasket?
If not then what else can it be?
ANd here is a close up
check your timing chain cover, valve cover, and oil pump, maximas seem to have problems with these areas leaking. If you have a leaking timing chain cover or oil pump, a shop fix will be expensive, so good luck. Get a flashlight and inspection mirror and check that area you circled by your firewall. If it is from the valve cover, it will be a pretty substantial smear if it is causing it to smoke.
Yeah re-sealing those leaks costs a lot of $ at repair shops. I had to pay around 300$ on my old Altima to get everything around the engine resealed (it had been in a wreck about 4 months before apparently the original seal had worn down and oil was slowly leaking).
shilov
Feb 19, 2024 09:40 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
