I did a compression test today.. n2o???
Old Oct 24, 2001 | 08:21 PM
wicked1044's Avatar
results are: 176, 174, 176, 176, 175, 174...
think i can hold some n2o?
Old Oct 24, 2001 | 09:42 PM
BriGuyMax's Avatar
with the proper fuel delivery...why the heck not????
Old Oct 24, 2001 | 09:58 PM
nizmolee's Avatar
i wonder if any guys using NOS had problems with auto tranny..
Old Oct 24, 2001 | 10:03 PM
got rice?'s Avatar
was the engine warm?
did you disable the fusible link to kill the fuel supply?
any any oil to see how the compression built up?
the numbers seem a little too good...
Old Oct 25, 2001 | 05:37 AM
Enduro's Avatar
Re: I did a compression test today.. n2o???
Those area really really nice and even numbers. Mine were much higher and weren't even across the plugs
Old Oct 25, 2001 | 05:42 AM
Sonic's Avatar
What kind of guage did you use to get numbers that accurate, most guages are only marked in 10s or 20s.
Old Oct 25, 2001 | 07:07 AM
wicked1044's Avatar
i used the compression tester at my friends shop...
it was a really nice unit. (high quality) it was in two pieces... one went into where the plug goes and the other connects the gauge.
the engine was warm and i did pull the fuse to kill the fuel.
the turned each test 5 times. the gauge built up pressure quickly.
if you want i can get the maker and part # of the unit, let me know...
Old Oct 25, 2001 | 07:25 AM
Sonic's Avatar
No, it's not a problem, I just was wondering how you got numbers like 176 instead of 175. BTW, stock is 185, min is 142, you are ok.
Old Oct 25, 2001 | 07:34 AM
wicked1044's Avatar
stock is 185??? you sure because i thought 185 was for a new car.
i'm wonding if my #s would have been a litte higher if i cranked it 6 times...
Old Oct 25, 2001 | 07:40 AM
theblue's Avatar
are you also the compression ****
MardiGrasMax's Avatar
I crank like 15 times per cylinder.
Old Oct 25, 2001 | 07:42 AM
wicked1044's Avatar
DAMNNN...
Old Oct 25, 2001 | 07:46 AM
Dreizehn's Avatar
The gauge only measures max compression. You can crank it all day and you should get a similar reading. Your valves exhaust the pressure in the cylinder.
Correct me if I'm wrong...
Old Oct 25, 2001 | 07:48 AM
Sonic's Avatar
Have you done yours?
Old Oct 25, 2001 | 07:52 AM
theblue's Avatar
nope
Old Oct 25, 2001 | 07:57 AM
Sonic's Avatar
nope
Get to it!! I want to see what the supercar holds.
Old Oct 25, 2001 | 08:06 AM
wicked1044's Avatar
are there any parts out there to make our engines stronger to hold more power and to increase the life of the engine?? (cams,etc..)
also Medicsonic, what #'s did you get???
Old Oct 25, 2001 | 08:11 AM
Sonic's Avatar
The answer to your first question:Pretty much no, but I think Turbo95Max had some custom made.
Second Question1-2-3-4-5-6)165,170,160,175,165,170
Old Oct 25, 2001 | 08:14 AM
wicked1044's Avatar
damn, thats what i thought...
custom parts=$$$
Old Oct 25, 2001 | 08:21 AM
Don in Texas's Avatar
Loss of ~8-10% is normal on compression. Once its broken in well, it will level off. The motor I bought with only 1900 miles on it had a 8-10 percent loss of compression (from the 185psi) when I tore it down. I don't have a clue what my compression is on my original motor, but
I should look just to find out what 110,000 miles, and some HARD races for the last 3 years will do to a Nissan VQ. I bet its not as low as you might think
Old Oct 25, 2001 | 08:25 AM
Sonic's Avatar
Dude, I LOVE that sig.
Old Oct 25, 2001 | 12:47 PM
got rice?'s Avatar
DAMNNN...
You only need to crank it seven times.
Old Oct 25, 2001 | 01:07 PM
SuDZ's Avatar
Yeah I gotta agree. Medic you should change the seal though.
SuDZ
Old Oct 25, 2001 | 01:16 PM
Sonic's Avatar
What's wrong with it?
Old Oct 25, 2001 | 01:23 PM
Why 5, why 7, It takes 15 for my gauge to stop going up, so thats about where I stop. Then its a true peak psi.
Old Oct 25, 2001 | 02:30 PM
got rice?'s Avatar
That's how I've been taught to do it. If you have four cylinders, crank it 5 times. If you have 8 cyl, 9 times
Old Oct 25, 2001 | 05:09 PM
Enduro's Avatar
Took me average between 9-11 cranks before the needle stops moving and it does change between each cylinder. Haynes manual recommends at least 7 compression strokes.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
