CLUTCH OR SLAVE
Old Dec 13, 2007 | 06:03 PM
maxboy325's Avatar
CLUTCH OR SLAVE
I press the pedal put it in first and nothing was slipping the other day now wont move the fluid is a little low ( just under the min line all help welcome
for any one who just whats to be a **** so be it thanks to any one else
Old Dec 13, 2007 | 06:07 PM
MorpheusZero's Avatar
It just changed overnight? It's probably the slave.
Old Dec 13, 2007 | 06:13 PM
OOmaxSE's Avatar
Press/depress the clutch many times (50) and check the clutch level again. It could be your rubber hose leaking or the slave is gone. You can also have someone press the clutch and you look for any fluid leaking right by the tranny (where the slave and rubber hose attach). Does the clutch feel normal or losing pressure?
Old Dec 13, 2007 | 06:18 PM
maxboy325's Avatar
pedal pressure is fine now but the other day it was kinda funky checked for leaks couldnt find one
Old Dec 13, 2007 | 06:19 PM
maxboy325's Avatar
forgot to metion i had to start it in gear to get it home not that far and when it started slipping i could smell clutch
Old Dec 13, 2007 | 06:37 PM
maxboy325's Avatar
maybe TOB(RELEASE TOOL)????
Old Dec 13, 2007 | 08:41 PM
maxboy325's Avatar
any one else??
Old Dec 14, 2007 | 03:59 PM
maxboy325's Avatar
NO ONE????
Old Dec 14, 2007 | 04:34 PM
Maximeltman's Avatar
just bleed it dude might have air in it or something
Old Dec 14, 2007 | 04:51 PM
KRRZ350's Avatar
It's cheap & easy to rebuild both. Well, reinstalling the master can be difficult. + one on the lower line. And don't forget there is TWO bleeders.
Old Dec 15, 2007 | 12:46 AM
jacobmh's Avatar
One day my res was empty. Had to pump the clutch to get it to work. Filled it then Bled it and nevertouched it since. Work great last long time
Old Dec 15, 2007 | 04:32 AM
dgeesaman's Avatar
Maintenance Monster
The clutch slave does fail from time to time on these cars.
Unbolt the slave - is there fluid leaking from it? Is there fluid leaking from the line?
(If you need one, I have a slave with clutch line and dr. side motor mount that I'll sell cheap - PM me)
Old Dec 16, 2007 | 08:50 PM
maxboy325's Avatar
no fluid leaking any where that i could see burnt clutch smell when drove it last now i can put it in 1st gear and release clutch and the car just idle does not shut off and wont move just rev
Old Dec 16, 2007 | 10:38 PM
Snypa's Avatar
i think you either have a smalllllllllllll leak or try bleeding the lines.
Old Dec 17, 2007 | 03:00 AM
dgeesaman's Avatar
Maintenance Monster
Take it to your mechanic.
Old Dec 17, 2007 | 08:43 AM
black_maxed95's Avatar
now fluid leaking any where that i could see burnt clutch smell when drove it last now i can put it in 1st gear and release clutch and the car just idle does not shut off and wont move just rev
dude man try using punctuation to make your posts readable. also try forming sentences longer than 3 words. i have to read your posts like 4 times to figure out what you are saying.
...yup i guess i am just being a ****...so be it.
Old Dec 17, 2007 | 01:27 PM
wirelessdude04's Avatar
my guess is to bleed it quite a few times over and over then go from there.
Old Dec 17, 2007 | 06:12 PM
kzoosho's Avatar
lol wth
Old Dec 17, 2007 | 06:55 PM
maxboy325's Avatar
Well I was trying to be short and to the point. Sorry it took YOU so long to read it! I guess some things are easier for others, but thanks anyway I am just surprized its only you later ****.
ps thanks to everyone else
Old Dec 18, 2007 | 01:44 PM
dgeesaman's Avatar
Maintenance Monster
It IS incredibly hard to read. Capital letters, commas, and periods don't take any more time once you get into the habit.
Dave
Old Dec 21, 2007 | 09:42 PM
maxboy325's Avatar
It was the clutch, I will try and post some pics of whats left of the old one
got a pretty good deal on the install. $450.00 I had my own parts new clutch and flywheel
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
