How can i roll my front fenders.
Old Dec 14, 2007 | 11:55 PM
maximaserg's Avatar
My tires rub a lil on the front when i turn, just wanted to see what is the best and easiest way to push the fenders a little up.
I heard something about a baseball bat before....
Old Dec 15, 2007 | 05:10 AM
WhiteA32's Avatar
Go to youtube.com search for it.
Old Dec 15, 2007 | 06:31 AM
Matt93SE's Avatar
STFU n00b!
are they rubbing on the inside or the outside?
mine always rubbed on the frame rail.. but I have a 3 gen so it's a bit diff.
Old Dec 15, 2007 | 08:16 AM
BLACKonBLACK98's Avatar
Former Vendor
if its at full turn its on the inside, meaning rolling/pulling won't help. the baseball bat is for pulling.
Old Dec 15, 2007 | 01:02 PM
maximaserg's Avatar
its on the inside. Its rubbing on the middle part of the inner fender, the one that kinda pops out more than the rest. It seems if i can just push on it with a baeball bat i can just push it inside or soemething.
Old Dec 15, 2007 | 01:24 PM
MrDicks95SE's Avatar
Offset Is Everything.
goto your local autoparts store ie: kragen pepboys and rent a fender roller. that will only roll the insides of the fender. i've tried the baseball method; it works but its not very good. if you want a cleaner roll, go with the roller. we've also used the roller for a slight fender pull as well.
Old Dec 15, 2007 | 01:48 PM
Matt93SE's Avatar
STFU n00b!
Umm say what?
pictures speak 1000 words.
Old Dec 15, 2007 | 02:10 PM
i30krab's Avatar
http://
Originally Posted by Matt93SE
Umm say what?
Old Dec 15, 2007 | 03:28 PM
WhiteA32's Avatar
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Dec 15, 2007 | 05:24 PM
i30krab's Avatar
Oops, sorry try this bat it's easier to use then the previos images.http://
Old Dec 15, 2007 | 05:28 PM
z00york145's Avatar
ahh now it makes more sense.
Old Dec 16, 2007 | 06:24 PM
Fast1one's Avatar
You don't need that fender roller, just a bat (hammer works too with some pressure on the outside) and a head gun...
Either way, WTH is rubbing? Is it just me, I don't get it
Old Dec 17, 2007 | 09:35 AM
the outside of the tire rubbing on the inner edge of the fender when the suspension compresses.
Old Dec 17, 2007 | 09:42 AM
Former Vendor
i think the problem is the inside of the tire rubbing the inner wheel well when he is turning. if thats the case, "reshaping" could help or spacers.
Old Dec 17, 2007 | 09:49 AM
"reshaping"... wearing down the inner fender lining you mean? if anything i wouldnt be too concerned about the tire rubbing on the lining if its just rubbing a little bit. thats an easy fix. on the other hand if its the actual fender taking chunks out of your sidewall, then yeah you need to do some modifications ie: fender rolling/pulling
Old Dec 17, 2007 | 12:03 PM
maximaserg's Avatar
Ok. The outside edge of the tire rubs a lil, and u can actually see it wearing away a lil, the tire that is. Its just that groove which ill try to pop in.
Those fender rollers are crazy, i didnt even know they make them.
PIX:
The black line is where it rubs when i have my 18's on. Its a grove which i want to just bend in. So.. do i just take a bat, lever it against the wheel and apply pressure?
maximaserg's Avatar
P.S these are not the wheels that rub.
Old Dec 17, 2007 | 01:26 PM
Fr33way™'s Avatar
Wild for Width
Is that the front splash guard? Just bend or pull it out of the way, it's fairly flexible. In the rear you can use a hammer.
That bat/hammer method is used for the OUTSIDE (painted portion) of the fender to gain clearance from the sidewall of the tire.
Old Dec 17, 2007 | 05:09 PM
maximaserg's Avatar
Yea its flexible. Yeap the front
Old Dec 17, 2007 | 08:21 PM
Bonka's Avatar
Schnell kaputt
Get a heat gun and reshape that section of the fender liner. It's easier to remould it if you take the entire piece off.
Old Dec 18, 2007 | 05:24 AM
huyqvu's Avatar
so is it rubbing the fender or the splash guard? i dont see any cuts in the tire. plus you said it only rubs when your turn? does it rub when you hit a bump?
wyobbagy
Jan 3, 2023 12:03 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
