Galloping noise from front end on acceleration
Old Dec 15, 2007 | 12:30 AM
made in china's Avatar
Whenever I accelerate from a stop or low speed, the front end of my car makes a "galloping" sound, like a series of clunks and pops. At first I thought loose motor mounts, loose subframe, etc. I check EVERYTHING that I personally have ever put a wrench on in the last few years to confirm that I did not leave any parts loose. I did recently change out my 3.0 for a 3.5 so that was the first thing I triple checked. Everything looks OK (driveaxles, hubs, mounts, subframe, etc)
The noise does not occur when I lift the front end off the ground and I apply engine power in drive with my foot on the gas. If I do so when the car is on the ground (apply power with foot on brakes) I can replicate the "galloping" sound as the front end deals with the engine power.
I am guessing that the struts are shot (or the strut bearings) and as the suspension transfers the load of acceleration the top bearing clunks. maybe lifting the car applies all the spring pressure to the strut bearings causing the noise to go away when the front end is lifted.
I probably could also use a entire front end rebuild, but I would like any ideas/opinions/experiences with this problem if anyone has any input.
Old Dec 15, 2007 | 08:49 AM
MorpheusZero's Avatar
It happens only as you're getting on the gas and the front suspension is uncompressing? Most likely it is the strut bearing. They are pretty easy to replace.
Struts generally don't make noises when they're done, they will just damp poorly.
Old Dec 15, 2007 | 09:40 AM
Edward Lee's Avatar
i vote engine mounts. You can check to see if they are bad by having a friend sit in the car and apply the brake. Then while the brake is applied, lay into the gas and see if the engine shifts its position. If it does....
Old Dec 15, 2007 | 10:20 AM
nismos14's Avatar
§è~® f®ÈÄk
Could be broken mounts/strut mounts/bearings.
Old Dec 15, 2007 | 10:48 AM
That was the first thing I looked at. I even checked to make sure they are still firmly bolted to the engine.
Old Dec 15, 2007 | 05:06 PM
Fr33way™'s Avatar
Wild for Width
It seems simple, but check your axle nuts as well. They can sound like hell if they are not torqued correctly.
Old Jan 12, 2008 | 09:51 PM
rm4628's Avatar
CLICK CLACK 1
I say mmounts check all
Old Jan 13, 2008 | 08:53 PM
maxtrax's Avatar
What about the wheel bearing. You can check them by rasing the wheel off the floor. With one hand on the top of the wheel and one at the bottom, try to rock it back and forth. There should be no movement, if there is the bearing is worn. Good luck.
Old Jan 13, 2008 | 08:59 PM
Qbridg3's Avatar
+1. Mine does.
Old Jan 13, 2008 | 09:30 PM
SKarpenz's Avatar
My 95 is doing the same thing. I figured it was the strut bearing. But since the shocks are almost all blown, I'm gonna upgrade the whole assemblies all around. Let us know how it works out.
Old Jan 13, 2008 | 10:03 PM
CRiME's Avatar
oem ftw!
did you ever figure out what the problem was? I have this too, or something very similar. if the car is rolling, there's no noise. once I get on the gas I can hear it. i've basically renewed the entire front end including LCA's and all 4 motor mounts. I had someone look at it and he told me the problem is that my radiator support is busted where the crossmember bolts up (body shop used a cheap aftermarket part when they rebuilt my car last year). That whole area is pretty much split and beginning to rust, and the crossmember has dropped down like an inch... I might have to find a place to weld it back together until I can afford to replace the entire lower rad support with an OEM piece. The more that I think about it, the more it starts to make sense.
Old Jan 13, 2008 | 10:08 PM
djfrestyl's Avatar
Suspension Yoda
I entered this thread simply to making a joke about mAd hoarsepower y0!
Old Jan 14, 2008 | 04:48 AM
I found one speed bump near my house that can cause the front end noise that the car makes when initially accelerating. My struts are blown and I reckon the strut bearings are clunking around when there is force or a certain kind of bump on the strut assembly.
Old Jan 14, 2008 | 06:37 AM
djfrestyl's Avatar
Suspension Yoda
Strut bearings don't ever clunk. Chances are it is your strut mount itself.
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
official_style
Aug 29, 2015 10:10 AM
cash94
Aug 27, 2015 08:09 AM
Samedi
Aug 12, 2015 01:54 AM
