A32 & A33 (00-01) Weight Log
Old Dec 20, 2007 | 12:52 AM
Ceasars Chariot's Avatar
Old Maxima Legend
Most of the parts are off my 1997 SE. There will be a few A33 5th Gen parts (00-01). Just a basic log of how much things weigh. Will eventually add links to other threads with weight reduction or weights of different parts off the A32.
If you have weighed anything from your 4th Gen and want to add to the thread just post up item, weight and what year car. This thread should aid in getting an idea on shipping quotes, the weight of parts in general, and weight reduction ideas.
Cheers
CC
Keywords: Weight Reduction list how much does part weigh
Weights and Weight Reduction Threads & Links
Lighter Maxdes.net
A32 Fuel Rail and Injectors - 4 lbs.
A32 Lower Intake Manifold (top shot) - 5 lbs.
A32 Lower Intake Manifold (bottom shot) - 5 lbs.
A32 Rear Valve Cover - 5 lbs.
A32 Upper Intake Manifold - 14 lbs.
Old Dec 20, 2007 | 12:58 AM
Old Maxima Legend
A33 5th Gen 2000-2001 Upper Intake Manifold - 17 lbs.
A33 5th Gen 2000-2001 Throttle Body and IACV - 4 lbs.
A32 Throttle Body - 3 lbs.
A32 Rear Coil Pack - .5 lbs.
A33 5th Gen Front Exhaust Manifold without O2 sensors and heat shields - 20 lbs.
Old Dec 20, 2007 | 01:05 AM
Old Maxima Legend
A32 - 97-99 Stillen Front Lip - 4 lbs.
A32 Hood - 42 lbs.
A32 OEM Flywheel ( resurfaced) * same weight as stock - 20 lbs.
A32 OEM Radiator out of A32 Nissan Cefiro, probably same as Maxima. Not sure how much fluid is still in was just drained - 18 lbs.
A32 Battery Tray - 2 lbs.
Old Dec 20, 2007 | 01:07 AM
Old Maxima Legend
A32 cross member with front/rear engine mounts - 26.5 lbs.
Old Dec 20, 2007 | 01:26 AM
MaxGordon7's Avatar
Originally Posted by Ceasars Chariot
A32 engine support bar or brace ( whats the correct term ?) - 26.5 lbs.
Old Dec 20, 2007 | 04:57 AM
JSMax's Avatar
Sold
/\I believe that is the lower sub-frame connector.
Old Dec 20, 2007 | 05:47 AM
ROCKART's Avatar
wants an I35
01 Alloy weighs 29.7 Lbs.
01 Alloy + Tire weighs 60 Lbs. on the dot.
Old Dec 20, 2007 | 06:32 AM
Fr33way™'s Avatar
Wild for Width
^ That depends on tire and tire size...
Old Dec 20, 2007 | 06:35 AM
ROCKART's Avatar
wants an I35
im sure the difference is negligible. but they were Nitto 225-50-17s.
Old Dec 20, 2007 | 09:45 AM
Nealoc187's Avatar
SLOW
tire weights can vary - there are tires in 235-45-17 that weigh as much as ~28lbs that I know of and tires that are as light as 21lbs in that size.
Old Dec 21, 2007 | 01:27 AM
Old Maxima Legend
Weight Log
A32 Cattman Performance 1st Gen Front Exhaust Header - 7 lbs.
A32 Cattman Performance 1st Gen Rear Exhaust Header - 6.5 lbs.
A32 Cattman Performance 1st Gen Y Section of Header setup - 6.5 lbs.
Odyssey Battery PC680 - 15 lbs or with Odyssey battery tray - 16 lbs
Old Dec 21, 2007 | 01:39 AM
Old Maxima Legend
A32 Sparkplug cover - to light to weigh equal to A33 DE-K cover
A33 Sparkplug cover - A33 DE-K cover to light to weigh. same weight as DE A32 (feather light)
A32 Starter Motor - 7 lbs.
A32 Alternator - 14 lbs.
A33 Lower Intake Manifold (swirl valves removed), fuel rail & injectors - 8lbs.
Old Dec 21, 2007 | 01:52 AM
Old Maxima Legend
Part Weigh In
A32 Center Console - 5 lbs.
A32 Glovebox - 4.5 lbs.
A32 Rear Door Panel thought it was a bit high but weighed in at 4.5 lbs
A32 Spare Tire - 26 lbs
Old Dec 21, 2007 | 04:09 PM
S1cTech's Avatar
heh.. awesome thread idea man.... but there are about 15,000 parts in a car... soo... yah... weighting everything and taking pictures will take a loooong time... but it is good to get a gen idea on what makes our cars 3000+ pounds...
Old Dec 21, 2007 | 05:36 PM
Old Maxima Legend
true, i think we could get some use out of it. all my weights are just aprrox. weights as my scales arent the best. but its close should you need to ship a part and wanted to hop on usps or something like that to get an idea on shipping. or vice versa.
i got heaps more to do, but like you say it just takes time. im using www.allyoucanupload.com to upload the images and selecting the thumbnail for forums link. again if anyone else has a camera handy and some scales and has some time pitch in.
i thought the small photos added a bit of personality to the thread.
user 11122324
42
Jul 18, 2022 03:35 PM
Smackasmith
Feb 1, 2016 12:40 AM
mpbclutch33
Sep 21, 2015 01:54 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
