Making The Horn Blow With The Hazard Lights
i have an idea, and i wouldnt know how to do it if it would. you know when you push the lock button on the key fob, and the hazard lights flash? well, when i rewired my foglights, i saw the wires for the horn, and thought that maybe you could tie in a wire between the horn and, maybe the light that flashes when you push the button. Or maybe hook it to something else, but it seems like that might work.. Although, i wouldnt want the lights to start flshing when i hit the horn... or would i..? oh well, anyway, you guys think this could work??
Re: Making The Horn Blow With The Hazard Lights
___________
95 SE
...i saw the wires for the horn, and thought that maybe you could tie in a wire between the horn and, maybe the light that flashes when you push the button
Re: drivindamax98
Originally posted by matty
Could I still do that to the top grille section because I have the front license plate ??
or would it look stupid ?
would it still work with the front licence plate ?
thanks
thanks
Re: Re: Making The Horn Blow With The Hazard Lights
Originally posted by Enduro
hmm...do you want the horns to go off when you need to use your hazard lights in emergency situation?
haaha, nooo but,
Originally posted by NiMax
if you can find the wire that is coming from the alarm that supply the input for the hazard to flash.
Imagine how loud that horn would be. Some cars have a muted horn "chirp" when the stocker alarms are turned on or off. I don't think you can duplicate the small chirp on a 4th gen. Applying power to the horn relay will cause the horn to beep at its normal intensity, far too loud to make the chirp convenient.
What Ford does for there F-150's is that you hit it once and it locks and if you hit it again after that...then it gives a warning beep to let you know you locked it. Thats good so if your in a hurry away from your car you know you locked it...plus his horn is loud as he**
Re: Re: Re: Making The Horn Blow With The Hazard Lights
haaha, nooo but,
i think that wouldnt let it flash with the emergency hazards..?
haaha, nooo but,
Re: ....
I am almost ready to do this but just never got around to. I found a solenoid (sp?) in the trunk latch area that sends pulses of signal to the blinkers. If you stand very close to the rear of the car and lock/unlock with the key fab, you can actually hear the selenoid. I used an ohmeter and figured out which circuits to hook up to the horn (there are 6 circuits if I recall and only two should be hooked up to the horn). I now just need to find the most efficient way to route the wire from the rear to the horn in the front.
Originally posted by Maximus97SE
Yes there is a way. Trip the alarm everytime you lock your car. That will get everyone's attention. That's your intention, isn't it? Why else would you want to have the horn beep when you lock your car.
Re: Re: ....
Originally posted by JdawgX
Ford does this with all of their cars with keyless entry, not just the F-150. Good idea I suppose, but it's still a ford
unless you get some circuitry built, forget it. forgot whos comment it was, but hazards = turn signals is correct.
if you wanna try it.. follow the steps for installing an aftermarket system. stop after you've pulled out the middle vents. (the clock, hazard, and defrost)
try to signal. your interior wont signal, neither will the external.
get the idea?
get the idea?
tsi6001
10-03-2022 10:23 PM
kirkhilles
08-08-2015 10:53 AM
yat70458
08-03-2015 01:16 PM
