help cant shut trunk lid!
Old Dec 27, 2007 | 05:14 PM
euromaxima's Avatar
I have a cf trunk lid and my battery died so I had to use the emerengcy pull wire I have inside the car and now my trunk lid wont shut, the latch seems to work fine and the pull wire is no pulling on it to keep it open, any ideas, I had the problem when I first installed the cf trunk lid.
thanks
Brandon
Old Dec 27, 2007 | 05:30 PM
andrei3333's Avatar
If its the same as oem mechanism then on the part thats inside the trunk there is a little switch/lever that you can pull/push i think
let me guess, thousands of dollars of audio is at stake here ;-)
Old Dec 27, 2007 | 05:33 PM
BLACKonBLACK98's Avatar
Former Vendor
might just need to adjust the latch assembly, although i don't know what would have caused it.
Old Dec 27, 2007 | 08:18 PM
SVI30's Avatar
On the lip below the trunk opening, the latch mechanism is held tight with 2 bolts. You can adjust the latch position after loosening these two bolts. Try the top position first and make sure the trunk can latch. Then gradually move down the latch.
My trunk had always been hard to close even when it was new.
REDinLV
Aug 15, 2024 12:30 AM
hayne
Oct 5, 2015 11:53 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
EdRomo86
Sep 12, 2015 07:49 PM
rbaker100
Sep 6, 2015 02:46 PM
