VQ30 ECU binary/hex addresses
Old May 8, 2009 | 06:37 PM
  #121
Nealoc187's Avatar
SLOW
Originally Posted by throttlehappy46
JWT chips are protected, they scramble the chips so if you tried to download them the binary is scrambled. Their boards 'decode' the scramble to make sense of it. Hence why you need to send a JWT back to them for reprogramming.
Nistune I believe are still working on getting their boards functioning in the VQ30 ECU's.
Bikirom is quite easy to tune and I intend on supplying a base tune that is 95% accurate for 95% of most I/H/E modified engines. That data logging ability will allow you to 'log' data and then send me the log file if you require help doing a custom touch up
For instance, moving the MAF closer or further from the throttle body will require a small adjustment of the throttle enrichment map, etc.
I have 2 weeks off at end of this month(been involved in a huge contract at work), will aim to have first five ECU's with V4 boards ready for US based testing mid July.
I've sent you a couple emails, I know you're busy though. I hope we can work together to get it tested still. Let me know.
Old May 24, 2009 | 07:52 PM
  #122
throttlehappy46's Avatar
Hey Nealoc187,
Your definitely on the list. I aim to send you through the first ECU as soon as it is assembled
Holidays start next week
Old May 24, 2009 | 08:17 PM
  #123
98SEBlackMax's Avatar
Maxima.org Insomniac
Hey Nealoc187,
I've been looking forward to this.
How long is the waiting list for this ECU? Also is it possible to send the daughterboard to me so I can solder it in? or do you want us to send the ECUs to you?
Old May 25, 2009 | 10:13 AM
  #124
Blackwind's Avatar
just an odd question. does climate affect tuning with ecu upgrades? meaning; will a car in a humid enviroment perform differently than a car in a desert enviroment?
Old May 25, 2009 | 10:20 AM
  #125
mtrai760's Avatar
'Trynna' is not a word
Short answer: Yes.
Old May 26, 2009 | 01:08 AM
  #126
If your capable of some baisc soldering, then the daughterboard can be sent over and then you just need to send the original base map(its extracted via the software) then use the activation code to enable the board.
Air flow meter does compensate to a large degree but yes, some adjustment can be required in extreme humidity changes etc.
Old Jun 8, 2009 | 07:51 AM
  #127
Around 1am in the morning here...
VQ35 VCT system is functional, I actually have a much more efficient way of running the VCT system now that references the AFM voltage at a given rpm point and with some basic data logging self learns how much PWM is required for maximum torque at the given 'cell' rpm points Interpolatation between cells is linear.
To do this calculation, I actually set the VCT system up the same way Bikirom uses its boost control system, with the CMPOS signal looped wired up like a MAP sensor and solenoid PWM varied between ranges to keep CMPOS ref within range.
VQ30 ECU info later this week, few late nights should make some heavy progress
Old Jun 15, 2009 | 12:48 AM
  #128
Rowan's Avatar
Great work. Interested in the Vq 30 ECU options.
Old Jun 15, 2009 | 06:20 AM
  #129
ajm8127's Avatar
Me also. If you need any help, let me know. I have electronics experience as well as firmware engineering. And there's just something about modifying the stock ECU that appeals to me.
Old Jun 15, 2009 | 09:24 PM
  #130
VQ30 ECU A18-E11-ER1 as per the JWT ECU database, on page 2 of this thread.
One V4 Bikirom board
One V4 Bikisoft Program
Testing and dyno tuning this week
Will be using the Tomei cams for now in my VQ35 with the V3 settings used to make sure it runs properly with the 'known good' tune I have in the RB25 ECU. Test it on a VQ30 Maxima next week and then send the first one out to Nealoc187 for USA testing
VQ35 testing has made a further development last night though, VCT is now a function of airflow from the MAF. If air flow is not increasing voltage(ie dropping airflow under increasing TPS voltage) then VCT solenoid PWM is altered to increase airflow and load, for maximum torque at all times. This also allows cam timing to be optimised for part throttle and allows extensive use of the volumetric efficiency table to give better fuel economy.
Old Jun 16, 2009 | 03:49 AM
  #131
Blackwind's Avatar
VQ30 ECU A18-E11-ER1 as per the JWT ECU database on page 2.
Martha stewart says:"And thats a good thing."
Old Jun 16, 2009 | 06:54 AM
  #132
maxine'sMan's Avatar
Hopefully you still have me in this line up, I have been waiting for this since you started posting about it in 2007. I have cash, ECU's, and access to a dyno ready to go whenever you are ready! Just let me know,.
Cheers.
Old Jun 16, 2009 | 07:56 AM
  #133
KRRZ350's Avatar
I'm still anxiously awaiting this as well, in fact I've come close to getting rid of the maxima and picking up a galant vr-4 just so I can tune with dsm-link
Old Jun 16, 2009 | 09:10 AM
  #134
Kevlo911's Avatar
Kevlo for President
I am down to get rid of my EU as soon as we can confirm it works. Let me know if you need any help
Old Jun 17, 2009 | 03:43 AM
  #135
Cheers.
Yeah, your definitely on the list
Will be in contact soon
Old Jun 17, 2009 | 11:01 AM
  #136
Nealoc187's Avatar
SLOW
Anxiously awaiting this. If I get it within enough time to do some thorough street testing I'll test it at a 2 day track even that I'm doing on July 18 and 19.
Old Jun 25, 2009 | 08:40 AM
  #137
V3 board in the '2nd' ECU which is getting a V4 board shortly. You can see the USB port sticking out of the stock 'slot'
Attaches via the two left hand side screws and the daughterboard solders into the factory main board via a ribbon cable
Old Jun 25, 2009 | 07:12 PM
  #138
emdot's Avatar
wow. ive been watching this thread since the beginning. this is going to be good. please, add me to your list of people to contact when this has been tested on US soil. thanks!
Old Jun 25, 2009 | 07:37 PM
  #139
grey99max's Avatar
LandShark has Cosworth
Damn - this will be the Holy Grail of VQ30 ECUs !! Since I'm using a stock '99 ECU with my much-modified car now, I am super interested in this mod
Watching closely for developments - this could do wonders for my coming Cosworth-based 3.5 engine.
(have spare ECUs - '99 and '98, $$$, and some electronics experience picked up doing medical device design and production).
Old Jun 30, 2009 | 03:56 PM
  #140
97Maximus's Avatar
Shift_custom
I would love to get my hands on one of these! As everyone says.. Keep us updated.. Great work!
Old Jun 30, 2009 | 10:10 PM
  #141
915Max's Avatar
Very interesting!!!
I tried to get Calumsult to do something very similar to this but he's been too occupied and focused on SR20 options.
I would definately be interested in this! I was about to purchase an EU, but I think I'll wait. I can really benefit froman extended rev limiter I hate the cut off at 6400.... The car pulls great and then all of a sudden, BAM! its like a huge tease!
Subscriing to get in line for this! I'm willing to solder the board myself as well.
I imagine there will be a huge waiting list for this! If there's already a list, please put me on it. hehehehe
Old Jul 1, 2009 | 09:21 AM
  #142
97Maximus's Avatar
Shift_custom
^^ agreed put me on the list please
Old Jul 2, 2009 | 03:51 PM
  #143
ajcool2's Avatar
Subscribing for results.
Old Jul 5, 2009 | 09:36 PM
  #144
xlcrew's Avatar
I’m Back
didnt see this covered, but will this type of set up work for a 5th gen 3L? very curious, would like to get rid of my SAFC II and raise the rev limit
Old Jul 6, 2009 | 02:38 AM
  #145
Any car or wiring loom that can run a 95/96/early 97 VQ30 ECU will work. All late 1997 onwards ECU's are different internally. I have bought seven ECU's so far and still grabbing as many as I can that are reasonably priced. Anyone who wants just the Bikirom board, will require a suitable VQ30 ECU that has the expansion slot.
Suitable ECU's that will take a board: http://jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Middle of page 6 for I30 ECU's
Bottom of page 8 for Maxima ECU's
Top of Page 9 for Maxima ECU's
All of the above ECU's will accept a Biki board, the 'stock' binary actually varies between boards though so 'sharing' tunes may cause problems. Hence if your ECU part number has not been 'cracked' yet, the stock tune will need to extracted so we can modify it to suit the Bikirom board.
Old Jul 6, 2009 | 08:16 AM
  #146
kajeno's Avatar
I have been waiting on this to start my 00VI swap. Can you give us an indication as to when you expect it to be completed? Cheers!
Old Jul 6, 2009 | 07:33 PM
  #147
Hey Nealoc,
Can you email me your postal address please? Get this one sent off so you have some time to play with the tuning for your car and make your deadline
Old Jul 6, 2009 | 09:13 PM
  #148
Nealoc187's Avatar
SLOW
I sent it to you in a PM.
Old Jul 7, 2009 | 04:26 PM
  #149
DAVE Sz's Avatar
Hooooooonda.....
is there going to be a limited run of v4 boards or would I still be able to get one a few months down the road?
Old Jul 7, 2009 | 04:35 PM
  #150
V4 boards will be around for a few months yet, I believe Lucas normally orders them in 500 lots. They do sell quickly though but he normally places a replacement order before he runs out. V4 only took so long due to a complete redesign from V3 with the mini-SD memory card slot and a few other features in the V4 boards
Old Jul 7, 2009 | 05:17 PM
  #151
DAVE Sz's Avatar
Hooooooonda.....
cool. I have a spare ECU so when the time comes, and if you're still doing this, I'll let you know...
Old Jul 7, 2009 | 07:58 PM
  #152
Blackwind's Avatar
cant remember if i asked this,will the 98's be able to use this ecu with no worries on changing any wiring?
Old Jul 7, 2009 | 07:59 PM
  #153
pmohr's Avatar
No more Maximas...
There are a pin or two that are in different locations (rear O2 signal wire, IIRC) but otherwise a 95/96 ECU will run in a '98 no problem.
Old Jul 7, 2009 | 08:04 PM
  #154
Blackwind's Avatar
i hope so.
Old Jul 16, 2009 | 07:37 PM
  #155
From a IM I got last night... may as well explain it to everyone
Just to clarify how I am using a VQ35 timing chain arrangement to run the VQ35 with VCT, without causing Cam/Crank sensor sequence conflicts in the VQ30 ECU when VCT is active...
I cheated... front bank head casting and exhaust cam is modified. Its also how I got the RB25 Cam position signal originally when I was running the RB25 ECU Replicate the stock ECU Cam signal and your set
Hopefully, Nealoc gets his ECU in time and we can make some more US progress along with an independant review
Old Jul 16, 2009 | 08:32 PM
  #156
grey99max's Avatar
So... you cut down a 3.0 intake gear (for the timing marks) and hung it on the left exhaust cam gear, then mounted the 3.0 cam sensor to match the correct 3.0 ECU timing? or something like that?
Sounds good - Pictures ??
Old Jul 21, 2009 | 08:51 PM
  #157
Close The 3.0 timing gear on the opposite end of the exhaust cam would be spinning in the opposite direction which puts firing sequence out. For it to work, I actually had the exhaust cam itself notched to replicate 3.0 CMPS signal waveform(originally used the RB25 waveform which is common knowledge locally which is why my RB25 ECU equipped VQ35 got up and running a lot quicker)
Old Jul 23, 2009 | 08:25 AM
  #158
grey99max's Avatar
OK - that's clever - now I really would like to see photos of this mod. What did you use for a cam sensor, and how did you mount it? I guess that you had the rear of the exhaust cam machined to match the 3.0 cam signal?
What would it take to get a '99 Maxima ECU modified for the Biki board? A free sample ECU to dissect?
Old Jul 23, 2009 | 09:08 AM
  #159
Kevlo911's Avatar
Kevlo for President
Problem with the 99 is that I believe they changed brands and that the insides are closer to an 00 than a 95-early97
Old Jul 23, 2009 | 05:30 PM
  #160
97 onwards do not have an expansion board socket... characterised by the 40 pin connecter on the board furthest from the ECU plug. The R33 Skyline ECU was also in the same situation, with no expansion socket although an R34 ECU with a different ECU supplier is chippable.
Engine, cams and new flywheel are due back from machining and balancing early next week. This forum helped in my decision to upgrade the oil pump if I am going to be spinning the engine hard Plenty of pictures to post once the engine is in the workshop and being re-assembled Even upload some videos now my video camera docking station is functional.
