bad knock sensor?
Old Jan 2, 2008 | 09:17 PM
maxim82's Avatar
bad knock sensor?
car has been a little hesitant when i step on the gas and just feels slugish to me but i have no codes. im trying to find out if disconnecting the ks will turn on the check engine light or damge something. i was thinking of just disconnecting it because if its not working it shouldnt make a difference but if it is working then ill be able to tell wether it is working or not.
Old Jan 2, 2008 | 09:27 PM
AndrewR2442's Avatar
Well I thought that the ecu sees it's signal... So then it would probably run in safe mode unconnected. I say... if you are over 150k you should replace it since it's gotten so much attention from our model car. I purchased mine off of ebay for about 60-70. And yea, when i need to get on the gas, i can now. When the knock sensor is bad it feels like you are running a four cylinder civic.
Old Jan 2, 2008 | 09:54 PM
maxim82's Avatar
i wanted to determine if it needs replacing. i know itll run in safe modeif its bad, but if its already running in safe mode now......there shouldnt be a difference if i disconnect it right?
Old Jan 2, 2008 | 11:03 PM
maxim82's Avatar
will any 4th gen ks fit in my 95
Old Jan 3, 2008 | 06:08 AM
ROCKART's Avatar
wants an I35
no, it should not cause a change if you are disconnecting a failed KS
yes, unless you are cali-spec, but i doubt you are becuase its rare
KS will NOT TRIP THE CHECK ENGINE LIGHT
Old Jan 3, 2008 | 09:49 AM
NmexMAX's Avatar
dot dot dot ...
All A32 knock sensors are the same, only difference is the procedure on how to change them (re:99's)
bbsitum
Sep 6, 2019 07:31 PM
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
