Engine whining
Old Jan 3, 2008 | 10:05 PM
Noslen's Avatar
Engine whining
I have a 1998 Maxima SE. The engine whine is present at start-up and get louder when you give it gas. Does anyone know what is causing this whining noise?
Old Jan 4, 2008 | 07:02 AM
S1cTech's Avatar
power steering pump possibly... Or could be someting else involving the belt driven area.
Old Jan 4, 2008 | 07:54 AM
hectorc's Avatar
Upper Midwest Wheel Whore
Check your belts, and anything that attaches to it.
Old Jan 4, 2008 | 08:53 AM
Gismo-T's Avatar
B!tch We Got a Problem
Have your altenator checked out, you may quailify for a replacement from the dealer...call them up & give them your vin #
Old Jan 4, 2008 | 09:26 AM
97SMG's Avatar
^^Didn't they stop doing that a while ago.........
Old Jan 4, 2008 | 09:28 AM
Tfvesquire's Avatar
Recall No More
You would be correct. I am looking to buy a 1998 Q45 and it has the same alternator recall as the Max. Three dealers said the free replacement had expired.
Old Jan 4, 2008 | 09:39 AM
Gismo-T's Avatar
You maybe be right Hector, didn't know the recall had expired!
Old Jan 4, 2008 | 11:52 AM
97SMG's Avatar
Me no Hexor............
Old Jan 4, 2008 | 12:08 PM
Gismo-T's Avatar
Oops...My badd...didn't check who posted quote...
Old Jan 4, 2008 | 02:05 PM
CRiME's Avatar
oem ftw!
bearings in the A/C compressor can lead to a similar whine. i'm dealing with that right now. I had to drive in some serious rain and my splash guards on that side are all busted. Since then, i have the sound. i plan to bypass the compressor with a 36" belt for now and deal with all that in the spring.
Old Jan 5, 2008 | 02:05 PM
maxima223's Avatar
98maxedout
have the same exact problem but mine whines some days and some days doesnt
Old Jan 8, 2008 | 07:36 PM
fro98665's Avatar
Alternator would be my guess. But after awhile that should identify itself because the battery will die(mine did). I had a whine and it was the alternator. I had the battery tested and Sears said good battery.
Old Jan 8, 2008 | 08:17 PM
mevjen's Avatar
The self-oil changing max
Your engine is a wuss, and hence it whines when it has to work...
Seriously now, I have had that problem with improper belt tension causing that, check both belts.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
