Quote:
That's interesting - http://forums.maxima.org/member.php?u=52650
I know all about PMs..Originally Posted by pmohr
http://forums.maxima.org/private.php?do=newpm&u=2701
I wanted this to be public so everyone could possibly see the info...
NWP Engineering.com
Quote:
Wrong Aaron on the second link........
That's pretty funny that someone dug up that name. That's an old account I created a long time ago when I thought something was wrong with my normal Aaron92SE account.NWP Engineering.com
Quote:
The 4th gen Maxima Intake Spacer Kit is still in the works. I know I've said that a few times, but this is NOT an easy kit to make. The design has been changed several times since the project was started. But just within the past few days, another design was decided on and now we can proceed with the project. We hope this is the final design!Originally Posted by mazzivart
I was just wondering how the development on our spacers is going?
But, my goal is to have the kit fully designed and tested and available for sale before the first major Maxima meet of the year in March 2008 in South Florida.
Thank you for your interest. I will be sure to bump this thread with any updates.
And if anybody has any questions, please do not hesitate to ask.
Aaron
NWP Engineering, Inc.
www.NWPEngineering.com
Edit: (1/7/08) I figured I would add some important information for those newcomers that don't know much about the NWP Engineering Phenolic Thermal Intake Spacers.
Here is the main vendor thread including pictures and product information of the VQ35DE Kit:
http://forums.maxima.org/showthread.php?t=404064
5th gen VQ35 Spacer Development Thread:
http://forums.maxima.org/showthread.php?t=384774
6th gen Spacer Development Thread:
http://forums.maxima.org/showthread.php?t=387128
Couple pics of the VQ35DE Kit:
NWP Engineering.com
Quote:
It's ok. I don't mind. So far there isn't a 4th gen Maxima Spacer Thread started yet. It gives the chance for people to ask questions for everyone to read.Originally Posted by Snypa
damnn, this is so not the way to contact a specific person.
A thread similar to this has been started in the 3rd, 5th, and 6th gen forum.
Just out of curiosity, whats the computability with an 00vi swap? I wouldn't think a space would make and difference at all, but yah never know.
Quote:
I was just thinking the same exact thing.Quote:
Seeing the other threads in the 5th and 3rd gen forums made me think of this...Originally Posted by Aaron92SE
It's ok. I don't mind. So far there isn't a 4th gen Maxima Spacer Thread started yet. It gives the chance for people to ask questions for everyone to read.A thread similar to this has been started in the 3rd, 5th, and 6th gen forum.
I wanted everyone to be able to see the info not just myself, since it pertains to the interests of all the 4th genners...
I went ahead and changed the title of the thread to fit the contents better.
Quote:
Too bad it doesn't change the actual title of the thread.Originally Posted by mazzivart
I'm very excited for the release of these spacers-it'll give me an excuse to get a MEVI
Oh I know...I also sent a request for a thread title change to kevlo...Originally Posted by EnervinE
Too bad it doesn't change the actual title of the thread.I'm very excited for the release of these spacers-it'll give me an excuse to get a MEVI
NWP Engineering.com
Quote:
As of right now, the spacers are port matched to the 4th gen VQ30DE LIM. The kit should include two thin port matched thermal spacers that goes between the LIM and heads. It will also include a 1/4" UIM Spacer that is port matched to the top of the LIM. So if you change the UIM to a 00vi, that shouldn't matter since you are keeping the stock LIM, right? And to finish the kit off, a 1/4" thick TB spacer will be port matched to the stock VQ30DE UIM.Originally Posted by MOHFpro90
So this kit should work with the MEVI and 00vi swap. But as for the 00vi, we know it's made of a plastic composite. But it's very likely that if the spacers provide a decent HP gain on the VQ30DE, then there should be some type of gain on the VQ30DEK 5th gen.
Well you have to remember that if you keep the 4th gen LIM you need to turn it 180 to make it work with the 00VI. I don't know if that will affect the design. However, there is a small percentage of members who have taken that route. Instead they go with the 5th gen LIM. You may have to have two designs.Originally Posted by Aaron92SE
As of right now, the spacers are port matched to the 4th gen VQ30DE LIM. The kit should include two thin port matched thermal spacers that goes between the LIM and heads. It will also include a 1/4" UIM Spacer that is port matched to the top of the LIM. So if you change the UIM to a 00vi, that shouldn't matter since you are keeping the stock LIM, right? And to finish the kit off, a 1/4" thick TB spacer will be port matched to the stock VQ30DE UIM.So this kit should work with the MEVI and 00vi swap. But as for the 00vi, we know it's made of a plastic composite. But it's very likely that if the spacers provide a decent HP gain on the VQ30DE, then there should be some type of gain on the VQ30DEK 5th gen.
NWP Engineering.com
Quote:
I see. It would be best to do two seperate kits then. Especially since the biggest feature of these spacers is that they are port matched perfectly to the stock ports! No other company takes the time to do this. They just copy gaskets and call it a day.Originally Posted by speed racer
I do feel there is enough demand to produce a kit for the VQ30DEK 00-01 Maxima. If things goes smoothly, that probably won't be ready until the Summer or Fall of 08.
Right now, the VQ30DE 95-99 Maxima Spacer Kit is top priority since the development for the VIAS/SSIM Block Plate is finished for the VQ35DE.
IIRC the bolt pattern for the UIM to the LIM is different from the DE to the DEK. those with 00VI will have to drill holes through the spacers to make it work with the bolts. Im pretty sure of this with my 00VI research but if I am wrong please simply correct me
Quote:
Big difference, yes.Originally Posted by black_maxed95
However, you only need 1 kit for 4th gens and one for 5th. Correct me if I am wrong but;
VQ30DE spacer for A32s and 00vis(with A32 LIM).
VQ30DEK spacer for A33s and oovis(with A33 LIM).
Aaron, do the spacers wrap around the bolts on the end of the LIM?
Powerman,
Quote:
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
NWP Engineering.com
Quote:
Nope, not really. But a final design has been chosen for the 4th gen kit.Originally Posted by Zack342
any status updates?
Quote:
Thermal Intake Spacers lower the intake manifold temps by an average of 40 degrees. They lengthen the intake runners and provide better low end and midrange power in the VQ35DE. They are port matched and eliminate the need for stock intake gaskets which are improperly sized. This improves airflow!Originally Posted by Powerman5115
Or what do these do?
Quote:
The design that has been chosen for the 4th gen Kit will wrap around the end studs on the LIM. But this can be changed since the drawings are not final just yet. If you feel this will help, please explain how. Thanks.Originally Posted by MOHFpro90
Just got a Mevi kit, hoping to be able to get a set of these upon installation of the Mevi. Considering I am not installing the kit just yet as I have the car stored, so it will be around spring '08 when I install. Any ideas on pricing yet? Thanks!
NWP Engineering.com
Quote:
Right now, they are expected to cost less than the VQ35DE Kit, which is priced at $225. I am hoping to keep it below $200. We'll see.Originally Posted by alcatranz518
NWP Engineering.com
Quote:
I will test the OEM intake manifold before and after the installation of Spacers. But it's possible we could do some dyno testing with the MEVI and Spacers. The 00vi testing will more than likely be done on the VQ30DEK with a seperate spacer kit specifically designed for that engine and intake manifold setup. One of the biggest and most important aspects of these spacers are that they are port matched. Since the ports on the 00vi and OEM 4th gen IM are not 100% alike, a seperate kit will need to be designed for the VQ30DEK.Originally Posted by t6378tp
when you start testing for results will you use the oem, mevi and 00VI intakes to compare how it effects each or just oem
Quote:
im glad this is moving along. i hope us MEVI users can use this to.Originally Posted by Aaron92SE
Quote:
cool, I was not sure if you happened to have a mevi test vehicleOriginally Posted by Aaron92SE
I have a feeling that these will help the MEVI croo more than the USIM croo...With lengthening the runner for the MEVI and help with the midrange slump it has without a tuned ECU...
NWP Engineering.com
Quote:
I don't have a MEVI test vehicle at the moment.Originally Posted by t6378tp
Quote:
Thank you. You are about 3 hours west of me. I'll let you know if I can't find a closer test vehicle.Originally Posted by MaximaSpd85
if you need a MEVI'd car to test here in NC im one of them....
NWP Engineering.com
Testing is complete for the 4th gen VQ30DE Intake Spacer Prototype!
Please visit the thread below for more details:
http://forums.maxima.org/showthread.php?t=554079
Thank you for all your support!
