VQ35 swap progress !
Old Feb 1, 2008 | 11:36 PM
  #81
NismoMaxman2's Avatar
The only 4.5 gen in da 956
Dam... thats a tiny garage... hats off to you, for being able to work in such tight space.
Old Feb 2, 2008 | 01:48 PM
  #82
rome06's Avatar
yeah its just a normal 2 car garage....all the **** is on one side and the car is in the other side
Old Feb 2, 2008 | 07:06 PM
  #83
imaking133's Avatar
wat do u guys think about droppin a awd rb into a 98 max
Old Feb 2, 2008 | 07:10 PM
  #84
goldtooth's Avatar
I think you should kill yourself and die in a fire. LOL
Old Feb 2, 2008 | 07:29 PM
  #85
adriena's Avatar
hahahaha
Old Feb 3, 2008 | 10:59 AM
  #86
toddemullins's Avatar
Looking good Andy. Make sure you take your time and don't rush through buttoning it up. Some people get anxious and rush the final steps. For you, it's going to be making sure the harness is in there and everything is wired up right. I want to hear about that thing running soon. I'm glad someone took it off my hands and will enjoy it.
Old Feb 3, 2008 | 12:37 PM
  #87
KRRZ350's Avatar
It's been done several times, but your '98 max won't work, you have to use the '97 chassis because the sheet metal and subframes are different in the rear, the '97 maximas come pre-drilled for the skyline differential, driveshaft, and suspension mounting, it's pretty much plug and play though, but everyone else that did it had an entire donor car to use, it makes it much easier.
You also need the full wiring harnes along with the flex capacitor, also IIRC one member was able to re-use the maxima's exhaust bearing, but it required alot of welding and he also had to use a muffler with a tip diameter of a least 4 inches.
Old Feb 3, 2008 | 12:45 PM
  #88
98MaXeDouT's Avatar
LOL this guys is a clown, don't pay attention.
The muffler tip diameter has to be at least 4.5"
Old Feb 3, 2008 | 05:31 PM
  #89
JSMax's Avatar
Sold
But he ended up having MAJOR problems with his headlight fluid. IIRC.
Lets get the story straight.
I couldn't resist. Sorry...
Did this 3.5 swap get finished yet?
Old Feb 3, 2008 | 09:58 PM
  #90
TurboS13Hatch's Avatar
Originally Posted by MOHFpro90
Im not sure what its like on the 3.5 but with the 3.0 a penny fits very nicely in the original screw sleeve. You really have to hammer and warp the penny, but it wont come out. We actually pushed it in further, and put some liquid gasket inside and out.
Nice swap, BTW, good luck!!!
Dude.. Nissan sells a EGR plug for like 4 bucks.. It's from the DE-K motor.
Old Feb 3, 2008 | 10:20 PM
  #91
nismology's Avatar
You and I think alike. I'd just order the OEM part.
Old Feb 3, 2008 | 11:27 PM
  #92
Really.. I mean, I could understand if it was a 100.00 part or something.. God knows that I can be "creative" when I have to.. My post was FYI for everyone.. he probably didn't realize that you could buy a plug for a couple bucks from Nissan. Now you know..
Old Feb 4, 2008 | 11:01 AM
  #93
adriena's Avatar
motor swap is almost done. theres a connector on the 97 wireing harness i have to replace the one nissan said was no good that does not fit. its the connector to the long fuse box on the diver side. the original conector which is off a 99 wiring harnes had 6 wires and the new harnes and connector wont fit and also has 8 wires. would anyone know how i can splice the 99 male connector into 97 harness female connector. I posted up a question and pics in the all motor section. Some help with that would greatly be appriciated. but after that all i need is fluids and a clutch line that was accidentally ripped out. and to reprogram my key because i had to get a new ecu because nissan also told me that was fried too. so i'm close taking a little bit of time cause there are some extras but its almost done.
Old Feb 4, 2008 | 11:02 AM
  #94
adriena's Avatar
when i get it done youll be the first to know and if you like i'll drive it over so you can see it and for a ride if you like. like i said before i'm always in the columbus area i have some family up there
Old Feb 4, 2008 | 08:46 PM
  #95
rome06's Avatar
Almost done with this damn thing guys. Had a couple questions as to where some of these vaccumm lines ran ....
i kno one goes to the intake but where does the bottom nipples run to?
Also on the throttle body side closest to the firewire there is another nipple that i dont know where to run it to, i attemped to take a picture of it so here it is lol ...
Also cant remember where this line ran to...
Old Feb 4, 2008 | 09:14 PM
  #96
91parkave's Avatar
to the bottom nipple...lol , put your two lates pictures together and you have your answer though...seriously
Old Feb 4, 2008 | 09:33 PM
  #97
JonBlz's Avatar
a.k.a. STuNtMAN
buddy get an 01 pathfinder TB and the adapter plates from Stepenmax so u can be cable driven its way better bro
Old Feb 5, 2008 | 05:09 AM
  #98
wagesgt903's Avatar
Im at about the same point you are on the swap and like Jonblz said get the pathfinder tb and the adapter from stephen max. I just got the adapter and its been so much easier than tryin to rig the tps to the stock one. Plus i got my pathy tb from car-part.com for 100 bucks so it wasnt bad. Good luck with getting everything buttoned up. I cant wait for mine
Old Feb 5, 2008 | 06:57 AM
  #99
KRRZ350's Avatar
WTF This post makes no sense?
DBW > Cable driven. Because it means you have VTC. PFTB > Cable modified DBW, because it means you have cruise control.
Old Feb 5, 2008 | 08:07 PM
  #100
made in china's Avatar
I have DBW and cruise control.
But yeah, jonblz post makes no sense. Sounds like someone without any real experience giving out *good* advice
Old Feb 14, 2008 | 06:56 PM
  #101
adriena's Avatar
wheres the best place to mount the TB cable and what should I use to mount it?
Old Feb 14, 2008 | 07:06 PM
  #102
You're probably going to have to get creative with a bracket that bolts in a couple places behind the TB on the bent section (elbow) that leads to the upper plenum. When I had the motor, I was going to TIG weld a plate to the elbow and bolt an OEM cable bracket to that. Wish I could help you out more.
Old Feb 14, 2008 | 07:52 PM
  #103
adriena's Avatar
yeah i had a bracket i was just wondering it if will weld to the plenum.
Old Feb 14, 2008 | 07:53 PM
  #104
adriena's Avatar
oh and by the way if anyones wondering the swap is finished. I just have to get it to nissan now to get the new ecu reprogrammed so that i can fire it up. But since every penny I have has already gone into the swap Ive got to wait a few days for either my tax return or some other money to come in.
Old Feb 19, 2008 | 05:49 AM
  #105
adriena's Avatar
Swaps done guys! Its at nissan getting the new ecu programmed. I forgot one major thing though. I didnt mount the braket i have that holds the TB cable. I was going to do it to the firewall but them I read here that thats bad and the car will jerk real bad. So my question is where can I mount it? Should I weld it? Drill a small hole in the plenum maybe and bolt it in? Does anyone have any pictures of their setup? Thanks.
Old Feb 19, 2008 | 05:58 AM
  #106
oldngivout's Avatar
Willing to learn
http://s188.photobucket.com/albums/z...t=DSC00141.jpg
Old Feb 19, 2008 | 06:23 AM
  #107
adriena's Avatar
nice thanks thats probably what i will do. How did you hook up your cruise control?
Old Feb 19, 2008 | 06:25 AM
  #108
adriena's Avatar
will the car just die soon after start if it is not mounted somewhere?
Old Feb 19, 2008 | 09:26 AM
  #109
oldngivout's Avatar
Willing to learn
Not sure what you mean, anyhow, if the stock bracket is secured to the intake in a similar manner to this, then you will be fine. The cruise cable then will simply mount in the bracket. Just remember, this also holds your throttle cable. In my opinion, it is very important that these two cables be securely mounted for trouble free operation. The last thing you want is runaway acceleration due to the bracket moving or something.
Old Feb 19, 2008 | 11:36 AM
  #110
2 Da Max's Avatar
..wow nice work bro.
Old May 17, 2008 | 11:28 PM
  #111
emanny's Avatar
I have a 98 max 5spd and I was thinking of swaping in a vq35 in it but was wondering if it will bolt up to the tranny and motor mounts and are there any other things I will have to change.
Old May 17, 2008 | 11:39 PM
  #112
holy poop man.
Go to the All Motor section and browse around.
Old May 18, 2008 | 01:03 PM
  #113
Bandfan1024's Avatar
That looks great man, keep up the good work!
Old Feb 20, 2009 | 12:02 AM
  #114
TJ_Max's Avatar
Paradox Systems Vendor
whoops.
Old Feb 20, 2009 | 07:07 AM
  #115
adriena's Avatar
whoops is right I forgot about this thread. Its been a while. It took me forever to get the car running but with the help of Pmohr we got it done. Running strong. just a few sensors out, egr codes because its deleted and an oil leak which i believe to be from maybe the OPS or the VCG. But thanks for everyones help. Sorry this is Super late. After the swap the car sat for MONTHS!
Old Feb 20, 2009 | 07:30 AM
  #116
MDeezy's Avatar
Originally Posted by TJ_Max
whoops.
thanks for the bump
Old Feb 20, 2009 | 09:10 PM
  #117
So how strong does it run Andy? With the port and polish I did on the intake and the cam degree advance, I'm curious on how it's doing in the car. You have to look me up next time you're in Columbus.
Old Mar 26, 2009 | 05:39 PM
  #118
Macof2003's Avatar
adriena.... hows the clutch holding?
Old Mar 28, 2009 | 05:52 PM
  #119
adriena's Avatar
clutch is holding up just fine doing a great job actually got bout 8000 miles on it and it grabs all of everything every time
Old Apr 5, 2009 | 02:41 PM
  #120
abhirud07's Avatar
nice man have lots of fun with this
