Installing a detector near the rear-view mirror, need to get 12 volts power up there
Old Jan 9, 2008 | 09:58 AM
Justaguy's Avatar
Is there an harness going to the mirror or around the top of the ceiling lights?
I'd like to mount my radar near the rear view mirror but need the 12V power up there...so I was thinking of getting that power from the ceiling lights.
What sort of wires are up there anyways?
Also, this site looks interesting...if it can be done.
http://www.invisicord.com
Old Jan 9, 2008 | 10:28 AM
Fr33way™'s Avatar
Wild for Width
Map light.
Old Jan 9, 2008 | 10:32 AM
pmohr's Avatar
No more Maximas...
It could be done, but it's not that great of an idea. Last thing you want is an exposed pin with B+ going through it.
Originally Posted by Fr33way™
Map light.
Old Jan 9, 2008 | 10:50 AM
Justaguy's Avatar
So I take it that I should open the map light, splice the wires and connect....do you know how many wires and what they do....I'm assuming there is a black for ground and a white or grey for power?
thanks
Old Jan 9, 2008 | 10:52 AM
pmohr's Avatar
No more Maximas...
thanks
Old Jan 9, 2008 | 11:04 AM
MAXC's Avatar
I have my V1 mounted up there & i ran a down to the fuse box. I used whats called add a fuse which is a 10 amp fuse that plugs intoy our fuse box like a regular fuse except it it has a wire attached to it. that way your radar will be fused, & you can ground it anywhere you like.
Old Jan 9, 2008 | 11:07 AM
MrDicks95SE's Avatar
Offset Is Everything.
what kind of detector is it? i have the 8500 x50 mounted up there with the Passport hardwire kit all the way down to the cigarette lighter.
Old Jan 9, 2008 | 11:15 AM
Justaguy's Avatar
It's a bell STi driver
MAXC: intoy? What is that? Or is that the fuse your talking about.
thanks
Old Jan 9, 2008 | 12:47 PM
99MAXSE-L's Avatar
Can you guys post some pics of your installs? I jsut got a V1 also, and would like to do a clean install up there.
I want it right below my rear view mirror, but tapping into the map light isnt a good idea.
How do you run the wires up top, through the pillar and down to the fuse box?
Old Jan 9, 2008 | 12:52 PM
pmohr's Avatar
No more Maximas...
How's that?
Convenient fused B+?
Old Jan 9, 2008 | 01:00 PM
99MAXSE-L's Avatar
I guess because just in case something blows, you atleast have the fuse (in the fuse box) to back up.
I need some setups with pics! Would love to see!
Old Jan 9, 2008 | 01:01 PM
pmohr's Avatar
No more Maximas...
Your argument against using it is that it's fused?
Old Jan 11, 2008 | 02:40 PM
Dubbya's Avatar
VK56 Inside
I have mine wired to the map light and have for some time. The only problem with it is that its always hot. As in my radar detector doesnt turn off when I turn the car off. I have to turn of the radar detector as well. Took a few jump starts to engrave that into my memory.
Old Jan 11, 2008 | 09:11 PM
ejarmol's Avatar
couldn't you use the power from the map lite then put a little rocker switch between it and the detector to turn power on/off?
Old Jan 11, 2008 | 11:46 PM
MAXC's Avatar
A rocker switch between it & the radar? uuhhmmm, wouldnt that be the same as just turning the radar off/on???
Old Jan 11, 2008 | 11:57 PM
ColombianMax's Avatar
lmao.. guess he didnt think about that one
I'm in for the pics of clean installs as well
Old Jan 12, 2008 | 08:30 AM
ejarmol's Avatar
i was just thinkin a little switch would be easier then maybe having to hold some button for 3 seconds i dno
Old Jan 12, 2008 | 10:51 AM
99BlackMaxMS's Avatar
I have an 8500 too and bought the hardwire kit about a month ago. I was planning on doing exactly what you are doing, snaking it through the headliner, down the a pillar to the cig lighter so that it still goes off when I turn the car off.
Old Jan 13, 2008 | 12:27 AM
MAXC's Avatar
Its pretty simple. All you have to do is run your power line across, between the headliner & the windshield, just tug on the haedliner a bit & tuck the wire under it. Run the wire down the a pillar & to the fuse box. Use whats called add-a-circuit, ita a fuse that plugs into your fuse box just like a regular fuse only it has about 2'' of wire & a butt connector on the end. One wire from the radar goes to ground & the other to the add-a-circuit. Thats it. You can run it to the cig. lighter but then you'll have to go back across under the dash which will call for a little more wire & a few zip ties. I'll put a few pics up if you want.
Old Jan 13, 2008 | 11:41 AM
darklegend06's Avatar
I just wired it through my cig lighter, The wire goes under the front dash then up my "A" pillar on the driver's side, and tucked under the ceiling.
Old Jan 13, 2008 | 12:47 PM
aznsap's Avatar
pics?
Old Jan 14, 2008 | 08:42 AM
Justaguy's Avatar
I think it's easier for me to use the map light. I removed the map light panel and saw two wires...I split the red wire (which was the power)...I didn't actually split the wire but used a little plastic clip that you can insert two wires into it, clamp it and it will make the connection (not sure what it's called). Then passed the power wire right under the mirror (the headliner and windshield).
I'll post some pics once I get my camera back.
Add-a-circuit?? Wow, neat! I can use this for my CB radio connection. Thanks for the tip!
vingodine
45
May 21, 2016 12:46 PM
JRod28
Feb 4, 2016 11:07 AM
Maxilano
Aug 31, 2015 07:33 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
wpr
Aug 5, 2015 03:28 AM
