Starting Problem
Old Jan 10, 2008 | 12:50 AM
97BLKMAXSE's Avatar
Starting Problem
For the past year my max has not been starting well. When the key is turned itll crank for a second then stop then crank again while keeping the key in the start position the entire time. It usually takes about 3 seconds of cranking then stoping then cranking before it starts. There is also some grinding sometimes, i thinks the starter on the fly wheel. At first my mechanic said fuel pressure regulator, replaced that and still happens. Also replaced battery and starter. Last time i saw my mechanic he now says it could be a sproket that controls the variable valve timing. Does that sound right? The car as 206,000 miles and i too think i has something to do with the timing. Has anyone else heard of a problem like this? Any help will be appreciated.
Old Jan 10, 2008 | 01:00 AM
SNOMAX's Avatar
PM me for LCA's!
Possibly grounding issues. You could try and make a cable that goes from the starter straight to the battery. It should cost about $5 or so. That would fix any grounding problems and they are easy to install. You can search the .org for people who have made their own grounding kits. You can buy them also, but then they cost more than $5.
Old Jan 10, 2008 | 08:01 AM
sureal00's Avatar
yeah i currently have that problem with my car ...it cranks and stops and i turn off then try starting it again it cranks some more then starts up with a grinding noise .below link says the gears inside have no more lube inside and that is the problem.Guess i'll replace my starter soon
http://www.motorvate.ca/mvp.php/516
Old Jan 10, 2008 | 12:00 PM
Capital15's Avatar
Might be a bad starter...but replacing that cable will save you some money...try that first!!
Old Jan 10, 2008 | 04:10 PM
njmaxseltd's Avatar
Please find another mechanic, he's not doing you any good.
There is no variable valve timing on our motors.
The ignition switch is a known failure item on our cars.
Check the flywheel and make sure the teeth aren't damaged.
Old Jan 11, 2008 | 03:33 PM
TunerMaxima3000's Avatar
to the grounding reccomendations that is exactly what it sounds like.
do you have a CEL?
Old Jan 11, 2008 | 03:50 PM
crazy97's Avatar
Grounding...
Old Jan 11, 2008 | 06:48 PM
^that thread saved my life
and exactly why you search
Old Jan 11, 2008 | 07:07 PM
QNO_A32's Avatar
are plugs and fuel filter fresh,if not try that...
Old Jan 11, 2008 | 08:05 PM
gixxer1's Avatar
sounds like a grounding issue, remove tranny and sand down surface between tranny and engine. i see allot on 5spd cars that had clutchs installed in the past. these vq's need a good ground between engine and trans or they will not run. crank rpm needs to be over 180 to start up.
Old Jan 11, 2008 | 08:15 PM
crazy97's Avatar
I didn't know that... I'll have to add your name to the list.
Old Jan 15, 2008 | 08:20 PM
killerVQ30DE's Avatar
Replace your ECTS if you've tried everything else its worth a go... will give you hard starts.. to the point that when it does start you have to hold the revs up for a bit
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
