Oil in Spark plug tube.
Jan 14, 2008 | 08:11 AM
I have found a fair amount of oil in the rear center spark plug tube. I think I need new valve cover gaskets. Problem is that in order to change those gaskets the intake manifold has to be removed. I can't find a write up on that procedure. The maintenence manual doesn't even address that. Anyone have a good procedure for removing that thing? I have heard that its not that hard to do.. just a little time consuming. If I can get it off I'll just go ahead and clean everything while I'm in there (TB, ect..). Any help would be appreciated..
Jan 14, 2008 | 08:21 AM
Stickies: http://www.vqpower.com/v2/readarticle.php?article_id=50
Not to mention:
http://forums.maxima.org/search.php -> http://forums.maxima.org/search.php?searchid=103980 ->
http://forums.maxima.org/showthread.php?t=380414,
http://forums.maxima.org/showthread.php?t=357465,
http://forums.maxima.org/showthread.php?t=337415,
http://forums.maxima.org/showthread.php?t=301633,
http://forums.maxima.org/showthread.php?t=287232,
http://forums.maxima.org/showthread.php?t=260844
Jan 14, 2008 | 08:28 AM
get a torque wrench if you can afford one.
Jan 14, 2008 | 09:32 AM
point proven....
