rattling noise when turning up bass
Old Jan 23, 2008 | 06:45 PM
tarun900's Avatar
Ok, I had this problem on my ex-car, a 95 Altima GXE, and now on my current car a 97 GXE Maxima. When I turn the bass up all the way or even just a bit, and like a rap song comes on, I hear like a metal rattling...its really annoying and means I pretty much have to listen to **** and keep the bass off unless I want to hear that annoying metal rattling sound. Anyone else experience this? Any solutions?
Old Jan 23, 2008 | 07:11 PM
fat_kid's Avatar
have a spoiler?
Old Jan 23, 2008 | 07:30 PM
tarun900's Avatar
No.
Old Jan 23, 2008 | 07:37 PM
dutch078's Avatar
keep it metal
stock system?
Old Jan 23, 2008 | 07:52 PM
SexiiMaxii's Avatar
Bass might be shot. Mine does just that, and it's the bass.
Old Jan 23, 2008 | 08:21 PM
tarun900's Avatar
Yea stock system.
Old Jan 23, 2008 | 08:59 PM
black_maxed95's Avatar
im almost certain based on your symptoms that you have a loose piece of metal somewhere that needs to be tightened.
or maybe you got some loose change in your armrest.
...seriously, it could be anything
Old Jan 23, 2008 | 09:03 PM
Fadrvr's Avatar
maybe its your trunk.
Old Jan 23, 2008 | 09:04 PM
idk...i bet its something either in or on his car
...sorry for the sarcasm but this thread sucks
Old Jan 23, 2008 | 09:49 PM
icaghost's Avatar
agreed, could be a lot of different things. I have the same model and the bass on the stock system speakers on yours would have almost certainly blown out by now (I replaced mine 2 years ago from a 98 gxe and the bass on those it terrible now too). If you want take off your front door panels and the things that hold the back speakers in and make sure they are bolted on tight, besides that just invest in a new set of speakers if it really bothers you that much
Old Jan 23, 2008 | 10:05 PM
max ride 41's Avatar
noob, noob, noob. please get a brain and come back later.....
Old Jan 23, 2008 | 10:40 PM
densetsu's Avatar
try pulling/pushing on the built in handle of the passenger side door panel. i had a vibration noise (could sound like a rattle i guess) coming from the passenger door panel shaking when the bass hit.
Old Jan 24, 2008 | 12:13 AM
our cars are old and when you crank up the volume even on the blose system it rattles. dynomat the trunk lid and doors and stop the insanity!!!!
Old Jan 24, 2008 | 05:53 AM
Snypa's Avatar
should be sumin really simple.
Old Jan 24, 2008 | 12:32 PM
joepino's Avatar
do you have a round about idea where it is coming from? trunk, ds door. ps door etc? if its the trunk i would check the power antena brackets and also your spare tire cover i took the cover out and replaced it with a 1/2 peice of wood cut to the form of the trunk carpet
Old Jan 24, 2008 | 12:47 PM
rcintorino's Avatar
I have a rattling sound in my 96max with bose. turned out to be some CD cases in the passenger side door sleeve :-p
Old Jan 24, 2008 | 03:26 PM
97maximaman's Avatar
Put in sound deadening, its relatively cheap if you buy it direct from the source. My stock system did that and so did the new head unit. Now i have some SD in the doors and im putting more in the trunk this week and its noticeably better. Go to the audio forum and theres a sticky called the definative sound deadening thread. Should answer all your questions.
Old Jan 25, 2008 | 09:24 AM
maximabebe's Avatar
Have you checked your rear deck lid where the stock 6.5" speakers sit? That badboy will rattle on occasion.
Old Jan 25, 2008 | 11:31 AM
maximaserg's Avatar
in the trunk there are tin metal bars that hold the trunk open. Mine were a lil too close and cause of the bass from my sub, they were hitting each other and rattling, so i duct taped them. lol
Ceck it, they run under the back speakers i think.
Old Jan 25, 2008 | 11:34 AM
emoore924's Avatar
1) Place right hand in front of you
2) Extend index finger out straight like you're pointing
3) Bend finger 90 degrees
4) Bend elbow so finger it pointed at side of head
5) Insert finger into ear canal
Repeat with left hand.
Old Jan 25, 2008 | 01:20 PM
MaxGordon7's Avatar
my ash tray use to rattle, just listen to where its coming from.
Old Jan 25, 2008 | 01:36 PM
MSchumacher's Avatar
why dont u put up the bass when the car is parked n go see where the rattling noise is coming from....duhhhhhhhhhh
Old May 27, 2008 | 08:29 PM
jmedeir1's Avatar
just dont listen to your music so loud
Old May 29, 2008 | 07:34 PM
vuiskool's Avatar
wow, i just tried that
haha
it could be one of your emergency roadside tools in the trunk. check if they are loose or not.
Old May 29, 2008 | 07:57 PM
Hexon's Avatar
Granted I have a system, but when the bass hits in my car the rear seat belt buckles with rattle against the plastic piece at the bottom of the belt. I have to make sure that I push the buckles all the way up before I start driving so that it doesn't get on my nerves. Other than that, just check to make sure there are no tears on the speaker cones, and try to find the direction the noise originates from so that you can isolate your problem.
Mar 12, 2020 12:06 AM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
