HELP!!! Bad knock sensor
Old Jan 25, 2008 | 11:24 AM
rroderiques77's Avatar
Demodded and Forgotten
I work 14 plus hours a day and don't have time to research this problem on the org, let alone repair it myself. My 99's with 170K miles check engine light came on and started flashing continously. I had to get it towed to the dealership. Upon scanning it, they found a knock sensor code. This is a code that has been interminently coming on and off for the last year or so. Last time the light came on. The codes were the KS and Catalytic Converter code. I replaced the cats so no problems until now. I also had to replace both upstream O2s later that year. My question is, can a faulty KS cause a driveability issue? Also, the estimate for the repair is $900.00. That seems kinda high. How labor involved is it? The IM has to come out I know. Maybe 3 to 4 hours labor to R&R the KS plus the part. Need your help with this one guys...
Old Jan 25, 2008 | 11:41 AM
adriena's Avatar
the knock sensor from nissan is about 170 bucks dont know why there asking that much then again it is the dealer. the knock sensor is one little magnet held on with one clip and a 12mm bolt i believe. Not completely sure about that but i know it is in a tight spot to get to but with about 20 to 30 minutes and some patience it is an easy fix by yourself. Its located under the intake manifold. And if you choose not to take it off to get to it be prepared to get cut a little trying to stick your hand down there to replace it. It is a very tight spot.
Old Jan 25, 2008 | 12:00 PM
densetsu's Avatar
http://www.motorvate.ca/mvp.php/507
... in the fifth sticky from the top. im sure you have enough time to read or run a search for 'knock sensor'...
Old Jan 25, 2008 | 12:03 PM
NmexMAX's Avatar
dot dot dot ...
Blinking SES = Multiple cylinder misfire = you need new coils. Who buys a KS for 170$? Try on here or eBay for $60-100.
Old Jan 25, 2008 | 12:04 PM
ROCKART's Avatar
wants an I35
its $125 from dave burnette at south point.
and get a kid or a girl with small wrists to help you. its cake.
now the CEL flashing means misfire i think. the CEL woudlnt come on from just the knock sensor. you need to find out what ELSE is causing it to pop.
Old Jan 25, 2008 | 12:08 PM
NmexMAX's Avatar
dot dot dot ...
His SES light is on because of the cat code, the cat code is on because of the coils.
Old Jan 25, 2008 | 12:47 PM
tallkid2201's Avatar
ugh.... i just got done doing that job a few days ago. got the ks for 160. took me about 30 min. just make sure youre patient if you do it because i wasnt and i cut up my hand really bad. basically sticking your hand into razorblades. car runs fine now.
Old Jan 25, 2008 | 01:01 PM
Husker Z's Avatar
Anyone ever use those Mechanics gloves while doing this? I have a pair that I've used at times and really like them. I bought them about a size too small so they are easy to manuver. Just a thought, plus, they are tacky and make it easy to pick things up.
Old Jan 25, 2008 | 01:06 PM
MaxGordon7's Avatar
sure the gloves will help protect.
Old Jan 25, 2008 | 01:16 PM
NmexMAX's Avatar
dot dot dot ...
Just take the damn manifold off Jesus.
Old Jan 25, 2008 | 02:05 PM
watut's Avatar
i paid like 49 bucks + tax for mine
Old Jan 30, 2008 | 08:44 AM
koolseven's Avatar
you should buy it in a different place for way less than that. If your knock sensor ir bad you will get a ticking noise in your engine.
Old Jan 30, 2008 | 08:55 AM
mowgli29's Avatar
Horizontally opposed.
no
Old Jan 30, 2008 | 09:41 AM
97_Roadrunner's Avatar
A friend of mine, just ordered his new ks for only $70.00.
http://catalog.eautopartscatalog.com...3a3ffe1c095a1f
Old Jan 30, 2008 | 09:43 AM
heynow's Avatar
Wow, ok.
heynow's Avatar
To the OP: Just go on ebay, they one for $60! Japanese made, just like OEM.
Old Feb 1, 2008 | 02:50 PM
Double E's Avatar
Ticking noise!! LOL.... read the forum much?
Old Feb 1, 2008 | 05:42 PM
kaneda_77's Avatar
take them off of cars in the junkyard and accidentally let them fall in your pocket...
Old Feb 1, 2008 | 05:58 PM
maxim82's Avatar
why buy from the dealer when you can get one here for a lot less by the way im selling one for $40.
bbsitum
Sep 6, 2019 07:31 PM
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
