Before I replace my broken clock, is there anything to check?
Old Jan 25, 2008 | 09:33 PM
cditto's Avatar
Before I shell out the $20-25 for a replacement clock, is there anything I can check besides the connections as to why it isn't working? Is there a fuse or something else to check?
Old Jan 25, 2008 | 09:52 PM
slow97maxima's Avatar
member
yes, try the very top right fuse (7.5amp) in the fuse panel under the wheel...in my case AFTER i bought a clock did i find it.
Old Jan 26, 2008 | 06:54 AM
JSMax's Avatar
Sold
hit your horn. If that dosn't work, it will be your fuse.
Horn, cig. lighter and clock are all on the same fuse.
good luck.
Old Jan 26, 2008 | 08:00 AM
Trajiksmax's Avatar
Proud Maxima Owner
What are the syptoms? Do you have the clock out of the car? If you do, check the clock's circuit board. Make sure there isn't any loose solder connections. This is what went wrong on mine. It was flickering when I went over bumps. If I hit the dash board it would come back on then randomly shut off. I ended up fixing it myself by re-soldering the pins on the board.
Old Jan 26, 2008 | 06:45 PM
joeahuerta's Avatar
Insert witty catch phrase here
I have the same problem with my clock, it goes on and off whenever it feels like it. No fuse problems or anything. I'm replacing it tomorrow. I think it's just a problem these cars sometimes have
Old Jan 26, 2008 | 08:10 PM
vqmaxman's Avatar
I replaced the fuse but It did not solve my problem. I will try this method.
The clock fades and It shuts off and you have to hit it to get it working. My clock fades away when I am going WOT and It resets back to 1:00.
Old Jan 26, 2008 | 08:14 PM
member
well if you find it cannot be fixed, i have a clock for you
Old Jan 26, 2008 | 08:22 PM
vqmaxman's Avatar
How much Is It and Is It in good condition.
Old Jan 26, 2008 | 10:45 PM
tallkid2201's Avatar
did you check wire connection?
also check for power in wires
Old May 27, 2008 | 06:18 PM
rodwin's Avatar
I experienced the same issues as you and have removed the clock, but I don't have any experience inspecting circuit boards for failed contact points. Do you know which pins were in need of re-soldering? I suspect the solution you provided will also work for me, but I just need assistance identifying the faulty pins.
Thank you.
Regards
Old May 28, 2008 | 07:38 AM
skuccio's max's Avatar
Beast Mode!!!
You should check the flux capacitor if you are having that problem
Old Mar 24, 2009 | 09:25 AM
kb2umj's Avatar
Resolder and repair
If you take the clock apart (it pops apart without tools) and resolder the four pins that make up the connector, your clock will work until the tranny drops.
The original factory solder job didn't have enough solder. The connections become fractured after all the bumps and potholes of life. The process should take less than an hour.....
Good luck.
Old Mar 24, 2009 | 09:36 AM
allensteiner21's Avatar
Good luck.
wow...this thread is almost a year old, man.
Old Mar 24, 2009 | 09:55 AM
95.maxima's Avatar
and he used the search feature like you are supposed to do to answer a VERY big problem of the 4th gen.
hell mine is fading in and out and i have to give it a good thump every time i get in to see it. without his post i never would have thought of doing that. so it was very helpful, unlike your post.
Old Mar 24, 2009 | 12:37 PM
Maxgig's Avatar
If your clock is turning off and resetting randomly it's time for a new one. I tried re-soldering mine and it didn't fix the problem. I eventually had to bite it and bought one off ebay for $10.
Old Mar 24, 2009 | 01:33 PM
my bad, i never realised that the clock fading was such a HUGE problem
post #4 already has the answer to the issue so maybe instead of just skimming through noobs(read: YOU) should read through more thoroughly?
here's an idea - lets all start digging up old threads and posting answers to questions nobody has asked in a long time
i'm not saying i'm perfect but there's much better ways to bump your post count - go to the general chat.
btw if you had a watch you wouldn't see the car clock fading as such a big problem of the 4th gen
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
