Car messed up
Old Jan 27, 2008 | 09:38 AM
fitbikerockin's Avatar
96 maxima se
Car messed up
ok so my car **** the bed. we were driving and all of the sudden when i shift nothing happens like its caught in neutral please help
Old Jan 27, 2008 | 10:05 AM
kefanman's Avatar
check your clutch fluid level. it's likely that the clutch isn't disengaging when you press down the pedal. if the fluid level is low or empty, you either have a leak in the clutch line or in the master cylinder or slave cylinder.
i actually have a very slow leak in my clutch line, every 3-4 months i have to refill my clutch fluid or else i stop being able to shift. i've ordered a new line, but haven't got around to installing it yet...
Old Jan 27, 2008 | 10:12 AM
kzoosho's Avatar
I have no idea about the car . Is it an auto 5sp? if 5 sp can you put it in gear with the car off. When it doesnt move does your speedo go up? These are all things that are needed here man.
Old Jan 27, 2008 | 10:40 AM
96 maxima se
ok yeah im just freaking out, its a 5 spd, it has all the fluid, pressure on the clutch is normal, when you let out the clutch it just revs and does not go anywhere like it is in neutral
Old Jan 27, 2008 | 11:17 AM
kzoosho's Avatar
OK does your speedo go up when you do this? check your axles and make sure they didnt break.
Old Jan 27, 2008 | 11:28 AM
densetsu's Avatar
ummmmm, if the car doesnt move then the clutch is dead... you press the clutch pedal IN to disengage the pressure plate from the clutch disk, with the pedal all the way OUT, it makes NO difference if you have no fluid, a leak, or any other problem with the clutch hydraulics, the effects of those issues cause inability to shift gears, meaning the car will always stay in gear. your problem as i understand it is you can shift into gears but you cannot accelerate when in any of them... you need a new clutch, your old one is burned.
Old Jan 27, 2008 | 01:47 PM
kefanman's Avatar
my bad, i thought you meant you couldn't get it into gear.
i agree, it sounds like your clutch is shot. did you notice the clutch slipping before it bit the dust?
Old Jan 27, 2008 | 02:34 PM
rcintorino's Avatar
maybe the shift linkage broke, that's another possibility as well. very unlikely, but then again we need more details as to what is happening.
does it go in any gear? can you pull it in and out of "gear" without grinding / anything happening?
Old Jan 27, 2008 | 03:08 PM
MaxGordon7's Avatar
yup replace slap tha Clutch!
Old Jan 27, 2008 | 03:27 PM
njmaxseltd's Avatar
Read his description again. Car was driving, then all of a sudden......
A clutch doesn't simply stop working, it slowly slips until it's fried. He's got nothing happening, no power to the wheels.
If it was hydraulic failure the clutch would remain engauged and he would not be able to shift into gear when standing still.
If he can shift the trans into gear and nothing happens when he lets the clutch out, I'd be looking at the tranny or even a broken drive shaft/CV joint, not the clutch.
Old Jan 27, 2008 | 03:57 PM
EnervinE's Avatar
i has college
Old Jan 27, 2008 | 03:58 PM
kzoosho's Avatar
Originally Posted by EnervinE
I have had them stop working while driving but i shatterd the pp. So they can stop working.
Old Jan 27, 2008 | 04:20 PM
densetsu's Avatar
i dont agree, the clutch can definetely stop working in a very short period of time. you can go from slipping to nothing in a matter of minutes, i have experienced it and know for certain it can happen. the problem is that the more it slips, the faster it will eat the clutch away, ive seen clutches where the driver felt the first slippage at one stop light and at the next had no ability to move the car. the chance of it being anything besides a worn out clutch is highly minimal, it would be very easy to notice something was seriously wrong if one broke ones axles, transmission, cv joint, shifter linkage, whatever. the clutch is the only component in the driveline that could quickly become inoperable without giving many clues to the untrained driver.
Old Jan 27, 2008 | 04:49 PM
JamesNH's Avatar
+1 for cvs or linkage. Can you engage gears with the car on, but not move?
MikesChevelle
Nov 23, 2024 11:17 AM
alixc
Aug 11, 2020 01:48 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
