How to change thermostat
Old Jan 27, 2008 | 06:31 PM
Coolsaber57's Avatar
FIRST! I looked at the fsm and did some searching, but they aren't very detailed. Also, the link for the thermostat change guide is broken, so no luck there.
Is there a guide on how to do this that is more than 3 sentences long? Do I have to completely drain the antifreeze from the car? Do I have to remove anything to get at the thermostat?
Thanks!
Old Jan 27, 2008 | 11:16 PM
pmohr's Avatar
No more Maximas...
Post in the stickies works for me
http://forums.maxima.org/showthread....15#post2506154
Then again, I actually read.
http://forums.maxima.org/showthread.php?t=543975
If you haven't changed coolant in a while, might as well drain it all and fill up with fresh. Otherwise, a fair amount will come out when you remove the hose, and some more when you take the thermostat physically out.
The post above details everything. 1 clamp, 3 bolts, and you're done..
The FSM is perfectly detailed:
That's all you need to do...
Old Jan 28, 2008 | 06:47 AM
Thanks, I was just hoping I could do this in my apt's garage, but I have to to go my parent's house to do it...bah!
Old Feb 6, 2008 | 02:07 PM
FishyMan's Avatar
Do you guys use the sealant or just the new gasket is fine?
Old Feb 7, 2008 | 06:08 AM
oldngivout's Avatar
Willing to learn
Factory gasket is superior and can be reused if you are careful.
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
