cat-converter deteriorate???
1. Ok, so i shot 2 sets of codes last 2-3 weeks.First was a p0158(bought new o2 sensor, bank2 sensor2) then p0156(didnt buy shieet).took it to the mechanic after installing the sensor and he told me that the cat seems to be deteriorating hence not holding pressure and also not keeping in the exhaust long enough in order for the o2sensors to give correct/precise reading. Can you guys really tell me if this makes sense.
2. On the other hand, his "fix" for this problem is for me to buy a new cat-converter and this should fix all lights and make the o2sensors "read" correctly.If this is really so,how do i go about looking a new cat.?
Will any cat do the job, or do you guys recommend something...maybe something that would increase power or performance in vehicle.
For me it makes no sense. The cat converter has nothing to do with holding pressure. I would find another shop to go to. Get a few opinions. The purpose of the cat is to reduce harmful emmisions not holding pressure. Sounds like the magical unicorn is poking holes in your cat again. please read how they work and come to your own conclusions. http://auto.howstuffworks.com/catalytic-converter.htm
ok, so can the catalytic converter deteriorate.? Can it cause the car to be throwing codes? If so what could the problem be. I hcanged the bank2 sensor 2 and light came back. the last light i got was P0156.
Any help would be appreciated.
Have you pulled it down to see how it looks, if it's blown out?
ok...thanx for responding. So im kinda preparing for the worst.If i happen to need a new cat, how much would it run.? Are those ebay cats worth buying. what would you guys buy?
find a shop thats willing to put on outside parts, ie, warpspeed, cattman, stillen, might as well replace the y-pipe with it for what they're gonna charge for just the cat. i got the warpspeed y-pipe with cat for 285.00 shipped, and i know it gonna run me another 200.00 or so for install. waiting on install until the nicer weather rolls around so the salt and crap does'nt eat away at it.
first off, i don't appreciate being threatened pmohr, its not being a smartass. its called reading the thread before you post up a similar response. i see it all the time, and its a little annoying, backing up someone's opinion is another thing all together. and i do know the difference, you seem to be on the defensive alot in here, ive been in here 2 years now, and i know the rules. relax, its only a car forum not the end of the world if someone is sarcastic once in awhile or types something you might not like to read.
Cali or fed spec? Got exact code #'s for us? FYI I've only see one bad cat out of a handful of cat codes that were caused by faulty o2's that didn't trip o2 codes, take a look at it like pmohr said, and pul the o2 sensors out and shake them, listen for a broken off tip. There are other tests that a compotent emmisions tech can perform as well, I don't think your mechanic falls under that catagory, did he take a look at your fuel trims, or inlet and outlet temps? Or did he just say "Yeah, I'm pretty sure that code is from a bad cat because it seems to be deteriorating"
Why don't you take it to an org member, I could easily name a few from the florida area that really know there siht, Nismology does work on the side
Also, hi-flow cat's suck *****. seeing as he's a PW, '99blackmaxms will surely stumble upon this thread and comment about how last night we had to rip his 3-month old warpspeed out yesterday because the honeycomb just decided to come loose and rattle around, actually today I was looking at it and the brick that came loose could tilt sideways, lol, yeah honeycomb sideways is REAL high flow.............
ok.so just out of curiousty,i called a local nissan stealership to find out how much a cat converter would cost.......$1028.00....wtf..there is no way i can/would buy this item AT ALL.you gotta help me out guys,my gas mileage sucks *** and i really need to find out what the prob is and get this light off.thanx.
RWCreative
Sep 21, 2015 11:01 AM
dss42
Sep 19, 2004 08:13 AM
BOSS
May 24, 2004 02:10 PM
Now, don’t ***** when I don’t spoonfeed ok?
