Energy Suspension Control ARM + Sway Bar Bushings
Old Sep 12, 2004 | 01:13 PM
dss42's Avatar
Energy Suspension Front End Control Arm Bushing Set Nissan Maxima 1995-99 (Black)
Part# 7.3111G
$28.32
http://www.ultrarev.com/ecart/shopexd.asp?id=29321
Energy Suspension Front End Control Arm Bushing Set Nissan Maxima 1995-99 (Red)
Part# 7.3111R
$28.32
http://www.ultrarev.com/ecart/shopexd.asp?id=29322
Energy Suspension Front Sway Bar Frame Bushings (20mm) Nissan Maxima 1995-99 (Black)
Part# 7.5118G
$6.76
http://www.ultrarev.com/ecart/shopexd.asp?id=29324
Or Call us toll free 1-877-858-7272 to order.
Performance Polyurethane
Control Arm Bushings For Front & Rear
• For both front and rear of suspensions on cars, trucks and SUVs.
• Maintains proper alignment under extreme conditions on and off -road and during competition.
• Improves vehicle handling, cornering and overall control.
• Full floating, for smoother operation.
• Made of Energy's HYPER-FLEX™ performance polyurethane to add performance and durability.
On the front of vehicles, they make a dramatic improvement in the way they handle–with quicker steering response and greater vehicle control. Whatever your demands, proper alignment (caster and camber) is better maintained by the use of the correct performance durometer of the bushing's material formulation.
On the rear, these control arm bushings are a must for controlling wheel hop and increasing cornering control for competition uses as well as maintaining alignment on and off-road.
All of Energy's control arm bushings are full-floating and non-binding... especially important when ride height is altered or greater suspension load is required. This is especially important for both lowered and raised vehicles that have had drastic suspension geometry modifications.
Energy's HYPER-FLEX™ performance polyurethane control arm bushings do not rot or deteriorate from oils or atmospheric conditions such as ozone, smog, road salt, chemicals, and other corrosives. They will not deteriorate in a few short years and cause that mushy, uncertain steering response like rubber O.E.M. ones often do.
When applicable, most sets come with zinc plated outer metal shells and are pre-lubricated with Energy's synthetic compound to inhibit binding.
In red or black color.
Performance Polyurethane Sway Bar Frame Bushings, Sway Bar End Links and Bushings
• Your vehicle's sway bar system will work at its maximum efficiency!
• Replaces that original, short lived and too-soft rubber.
• Easy to install with basic tools.
• Made of rugged Energy's HYPER-FLEX™ performance polyurethane material and the hardware is heavy duty–for lasting durability.
Improved handling, low cost, and easy installation are just some of the reasons these components are so popular! Dollar-for-dollar, Energy Suspension's sway bar bushings and end links offer the greatest improvement in performance handling on: cars, trucks and sport utility vehicles.
Working with Energy's HYPER-FLEX™ performance polyurethane Sway Bar End Links (for the vehicle control arms, etc.), our HYPER-FLEX™ Sway Bar Bushings (for the vehicle frame) makes the sway bar system much more effective. It does this by the use of increased durometers of the polyurethane bushing components. In effect, it's similar to installing a higher performance, heavier duty sway bar system, but at a fraction of the cost!
Energy's Sway Bar Bushings are available either as Standard or Greaseable Types. Sets come complete with corrosion resistant zinc and gold irradiate-plated strong 3/8" grade 5 bolts, nylon insertlock nuts (to prevent loosening), heavy gauge washers, and mounting brackets. All sets are available with either red or black polyurethane.
Additionally, Energy's special formula HYPER-FLEX™ polyurethane material assures long-lasting performance, unlike many O.E.M. rubber components.
These components are very critical to handling of a vehicle. By this very fact, one should definitely consider these components for a great performance upgrade for no matter what you drive!
Old Sep 12, 2004 | 04:29 PM
Mizeree_X's Avatar
Getting back to his roots
I wish you had posted this on friday. I ordered a bunch of Energy suspension stuff that day
Old Sep 13, 2004 | 07:21 PM
2k2nyc's Avatar
How about for the 2002-3 models?
Old Sep 14, 2004 | 07:33 AM
dss42's Avatar
They dont seem to make anything for the years yet.
Old Sep 19, 2004 | 08:13 AM
panda_1's Avatar
how bout the 2k-2k1 models?
Starrider
Dec 18, 2015 04:43 AM
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
Bonka
Sep 14, 2015 11:18 PM
