Eibach springs- do i need the camber kit?
Old Feb 4, 2008 | 07:42 AM
wagesgt903's Avatar
I gonna order the eibach springs and was just wondering if anyone was able to get the camber right without the camber kit?
Old Feb 4, 2008 | 07:55 AM
hectorc's Avatar
Upper Midwest Wheel Whore
No camber kit needed.
Old Feb 4, 2008 | 07:57 AM
jblinga's Avatar
It won't be perfect but it will be within tolerance. No kit needed.
Old Feb 4, 2008 | 08:16 AM
Grand_hustle17's Avatar
it's not the lowest drop so no camber kit needed, i,ve had 20's (FTL) on my 4th gen with eibachs
Old Feb 4, 2008 | 10:36 AM
mowgli29's Avatar
Horizontally opposed.
you don't need a kit. yank on the top of the wheel when bolting the strut to the knuckle. this will give you the least negative camber possible. I ended up about 1/5 of a degree out of spec. not bad at all.
Old Feb 4, 2008 | 09:38 PM
99grnmaxgxe's Avatar
But you will need an alignment.
Old Feb 5, 2008 | 04:43 AM
JSMax's Avatar
Sold
any sort of suspension work requires an alignment.
Old Feb 5, 2008 | 05:03 AM
wagesgt903's Avatar
Ya i know but i work at a shop so im gonna do the the alignment miyself i just didnt know if anyone was able to get it back in spec without the camber kit. Have you guys been pretty happy with them or would you go lower?
Old Feb 5, 2008 | 06:15 AM
mowgli29's Avatar
kinda wish I'd gone with coilovers. for about 100 bucks more I coulda got some teins... o well, as far as struts/springs go, I think I have a great combo. the eibachs give a moderate drop that looks pretty good. any lower and I don't see how there would be any travel left. I don't have too much travel as it is...
Old Feb 5, 2008 | 07:04 AM
wagesgt903's Avatar
Are you running the stock struts still?
Old Feb 5, 2008 | 07:30 AM
mowgli29's Avatar
me? no, if you check out my sig ^^^ I've got Tokico Illumina struts. They have 5 way adjustable dampening. IMO, best struts you can get for the max.
Old Feb 5, 2008 | 09:40 AM
jblinga's Avatar
Happy with the drop height but eibachs are stiff as a *****. Along with KYB AGX even on the softest setting is a pretty rough ride. Not great for a daily driver if you want a smooth, cushy ride. But handling was much improved over stock!
Old Feb 5, 2008 | 09:55 AM
mowgli29's Avatar
stiff? yes. But I have my struts on the hardest setting and I got used to it. It's not really that hard to tolerate, especially if you're willing to compromise for better handling.
Old Feb 5, 2008 | 10:07 AM
jblinga's Avatar
Yeah I've had mine for three + years now and I'm used to it. I was just letting him know about the ride eibachs give your car. They're said to be about 50% stiffer then stock springs. But again the improvement in handling is worth it!!
Old Feb 5, 2008 | 10:25 AM
mowgli29's Avatar
I'll stop posting, and let other people post now...
Old Feb 5, 2008 | 11:57 AM
Delvin's Avatar
The only way YOU will know if YOUR car will need a camber kit after any drop is by taking it to get it aligned. On average with an Eibach drop you wont need a kit but 2 cars with the same brands of spring/strut combos probably wont have identical camber specs.
Old Feb 5, 2008 | 05:45 PM
vilmaxima's Avatar
^^^thats right, I have the camber kit but after getting an alignment, and seeing the printout, you dont really need it, but then again every cars alignment is defferent.
Old Feb 5, 2008 | 06:53 PM
Tuna's Avatar
I got Eibachs with the AGX's and when I went to get an alignment not too long ago, they told me to get the camber bolts to get it adjusted right. I think they charged me $15 more for the bolts if I recall correctly.
Old Feb 6, 2008 | 04:46 AM
wagesgt903's Avatar
Ya the kits not bad so i guess ill just get it. How bad of an idea is it to run the springs with the stock struts?
Old Feb 6, 2008 | 10:20 AM
Tuna's Avatar
Old Feb 6, 2008 | 10:30 AM
tvis's Avatar
Exactly, and I'm surprised it took till the 6th post for someone to say that.
Old Feb 6, 2008 | 02:09 PM
vilmaxima's Avatar
Also if u get an alignement DONT get 4 wheel, since our back camber is not adjustable. U only need 2 wheel alignement(front).
Old Feb 6, 2008 | 04:51 PM
Delvin's Avatar
I dont know of anyone that gives you the option of a two or four wheel alignment anymore. But it is a good pointer in case anyone runs into a place that still does.
Old Feb 7, 2008 | 05:34 AM
wagesgt903's Avatar
So no on stock struts?
Old Feb 7, 2008 | 11:49 AM
Delvin's Avatar
It all depends. I'm one of the first to say that you should change the stock struts out with new springs but I ran on stock struts for about 9 months (and they held up to S-Techs somehow) because I was willing to sacrifice the ride comfort for the look I was going for. If all you have in your budget for now is the springs then just do that for now but beware that the ride may not be as you would like it to be. Also, if you save up and get the struts (and front mounts too!) and have them both done at the same time you won't have to pay labor twice, unless you are a DIYer or got some help, you'll save in the long run.
Old Feb 7, 2008 | 05:35 PM
wagesgt903's Avatar
The labor is no problem since i work at a shop but i guess ill just have to do the springs for now.
Old Feb 7, 2008 | 10:54 PM
wiggafly808's Avatar
+1
I went to a shop after putting on S techs, and i was quoted $250 per wheel ($1000 )for installation of a camber kit, on top of alignment.
I did some research, found out the backs shouldnt be out of alignment, and told them. They said "oh".
I purchased camber bolts for $27 off ebay, put em in myself in about 30 min, and got alignment.
Everything is in spec and no problems so far (4 months).
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
