NOS guys....fuel pressure problem with my NOS...
ok...so this has been happening ALOT lately...and at perfect bottle pressure too. I FINALLY got my guages in today and this is what I discovered....when I spray...it's NOT a smooth pull like it used to be...it gets jerky (50-shot...stock fuel system, FPSS not hooked up) and now with my Fuel pressure gauge installed I can see whats happening. When I go full throttle off the bottle...my car pulls smoothly and normally..at 48-50 psi (FP). When I spray it hits HARD and pulls normally for about 2 seconds..and the FP comes up to around 62-63 psi...but then the acceleration gets all jerky and the FP guage needle jumps around.....my A/F guage just reads the same 3 green and 1-2 yellow the whole time. then when I let off the accel...the FP jumps to around 70psi...and then goes back to Idle pressure...do I need a new fuel pump??? Has anyone else experienced this???? Could it be my fuel pressure regulator??
![](https://maxima.org/forums/images/smilies/support.gif)
Most likely the fuel pump or something wrong with the second soleniod that's suppose raise the fuel pressure when nitrous is on. I'm not very familiar with dry kit, but I would check the solenoids first. Nissan fuel pump rarely goes bad.
Erik
Re: NOS guys....fuel pressure problem with my NOS...
Re: Re: NOS guys....fuel pressure problem with my NOS...
Originally posted by dmbmaxima88
so how'd the 300zx pod work?
www.autoperformanceengineering.com
FPD006 (it says eclipse but it's the one you need)
$118 shipped
255lph, all the fuel you'll ever need and more
Install takes 20 minutes max
Good luck.
$118 shipped
Good luck.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
$118 shipped
Good luck.
$118 shipped
Good luck.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
will I need an adjustable FPR too??? Will I run too rich off the bottle???
unfortunately, yes, you will run a bit rich off the bottle unless you get a regulator. Ive been waiting for the $$$ to buy a regulator myself... ![Frown](https://maxima.org/forums/images/smilies/frown.gif)
yea...now I just need the $$$ for it![Frown](https://maxima.org/forums/images/smilies/frown.gif)
unfortunately, yes, you will run a bit rich off the bottle unless you get a regulator. Ive been waiting for the $$$ to buy a regulator myself...![Frown](https://maxima.org/forums/images/smilies/frown.gif)
will I run rich during normal driving...or only full throttle off the bottle???? doesn't the ECU constantly vary the mixture during normal partial throttle driving?
yes it does but it can't compensate enough for the different fuel pump.
03-12-2020 12:06 AM
RWCreative
09-21-2015 11:01 AM
