HELP ASAP - DOOR LOCK FROZEN
Old Feb 11, 2008 | 04:40 AM
LeVeL's Avatar
Key barely turns. Burned the hell out of it with my lighter, sprayed WD40 into the lock, door gap, and window sill - nothing works. UGHHH
Any suggestions? Maybe theres a way to open the trunk pass-through from the trunk? The trunk does open but I couldnt put the gate down and the manual doesnt tell you if you can...
Old Feb 11, 2008 | 05:11 AM
JtzMax's Avatar
Whatchyou say?
best bet mate is hot water ... nothing that will gum up the lock. our trunks don't allow you to "pass through", it's just a ski or fishing pole - center fold down. the wd-40 is baddddd stuff - especially for the rubber sill. hot water .....
Old Feb 11, 2008 | 05:13 AM
LeVeL's Avatar
Hot water will work, Im sure, but 20 minutes later it will turn to ice and I'll be stuck with the same problem in a parking lot
Old Feb 11, 2008 | 05:21 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Then use hot water again when you leave the parking lot?
Old Feb 11, 2008 | 08:19 AM
LeVeL's Avatar
Well, problem solved - it took lots and lots of WD40 but about 2 hours after I first walked up to the car, I managed to unlock it.
Old Feb 11, 2008 | 06:20 PM
Fasteddie01's Avatar
Maybe you should spray some silicone lube into it - jtz's right, WD40 strips lube out with the water/dirt. doesn't leave much of it's own lube.
Old Feb 11, 2008 | 07:24 PM
VQ30DETT's Avatar
i used break-free(gun cleaning stuff) for my door locks, works good. haven't had any problems since
Old Feb 11, 2008 | 07:49 PM
maxx0831's Avatar
wut if u spray lock de icer inside
Old Feb 11, 2008 | 07:58 PM
UkiSash's Avatar
next time just use a hair dryer.... if water got in the lock and froze that should unfreeze it, i guess. on a side .. DAAMN its been cold these past two days!
Old Feb 11, 2008 | 08:17 PM
JtzMax's Avatar
Whatchyou say?
hair dryer .... lol, I guess you could, but you'll need power to do that. (hard to find in a parking lot)
I used a mix of salt and hot water this morning, we get ice storms on the regular here. didn't have any problems the rest of the day, even though it kept freezing rain all day. I'd also sugesst maybe the window washer fluid with anti-freeze (properties) in it ... find it at any wal-mart, Prestone - yellow jug. good stuff - and I put a bit in a spray bottle and use it that way. short of caring a pocket tourch with you ... water, cold or hot really, usually works ok. even the cold will be warmer than the ice ... so it's not all bad. if it's in the lock ... try the other door. I have to do that from time to time to get into my car. you can try to leave a rear door unlocked (not many people are gonna be out to nick your stereo in cold - wet weather)
freekin ice .... last year I lost power for a week and a half due to the ice on the power lines and limbs ... SUCKED! hope not again ...
Old Feb 11, 2008 | 08:27 PM
huyqvu's Avatar
happened to me yesterday. was like -14 windchill here yesterday morning. nearly froze my hands off trying to get the key to turn. got some royal purple maxfilm. sprayed i a couple of shots into each lock. by the time i put the can up and back out it rotated smoothly. better than before. cold again this morning and locks werent a bit froze at all.
Old Feb 11, 2008 | 08:32 PM
kaneda_77's Avatar
use graphite lube($3 at autozone).. it doesn't freeze or breakdown parts in the lock.
wd-40 makes your problem worse in the end
Old Feb 12, 2008 | 05:27 AM
LeVeL's Avatar
Thanks guys.
huyqvu - yep, we had wind chills of around -15 here yesterday, and I also froze my hands off - they still hurt lol
Someone told me that youre not supposed to use hair dryers outside? Is this true? As far as water is concerned - it will just freeze up more within minutes and I'll get stuck in a parking lot where looking for hot water is a pita. How is wd40 bad?
Old Feb 12, 2008 | 09:03 AM
LILMAN's Avatar
Sounds like you should invest in a key fob! U shouldn't have that problem with it.
Old Feb 12, 2008 | 02:52 PM
honor_your_life's Avatar
-15 an your hands froze?! Here it is -30 to -50! Now that is cold! Use lock de-icer.
Old Feb 12, 2008 | 03:14 PM
huyqvu's Avatar
wd40 breaks down the viscocity of the grease in the lock mechanism. try to find a bottle of royal purple maxfilm. can use it on other stuff too.
Old Feb 12, 2008 | 03:44 PM
Mctwist77's Avatar
Yeah winter in MASS sucks!
Old Feb 12, 2008 | 03:52 PM
LeVeL's Avatar
I wasnt wearing gloves
I grew up in Moscow... believe me, I know all about cold temps
Old Feb 12, 2008 | 05:20 PM
kaneda_77's Avatar
that's why i left worcester.... suckd as$!
that... and it was wusta...lol.
Old Feb 12, 2008 | 05:41 PM
LeVeL's Avatar
Haha I live in worcester... what an armpit
Old Feb 12, 2008 | 06:22 PM
bellardo89's Avatar
yea use break free this **** for guns it similar to what i used!
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
