3.5 VQswap cam spacers....and a few other?
Old Feb 11, 2008 | 05:58 PM
Jarods7920's Avatar
Hey does anyone know where i can get a spacers for the cams for my 3.5 swap. Also what harness am i going to use for the swap am i using the 3.5 harness or just my 3.0 harness? If i have to use a 3.5 harness can i use an auto harness or does it have to be from a manual? Thanks in advance.
Jarod
Old Feb 12, 2008 | 07:53 AM
97SMG's Avatar
It all depends what route you are going to take, but to clarify things, you could use either one...........Just for reference 3.5 auto/manual harness = same difference as far as the swap goes.........
Old Feb 12, 2008 | 09:18 AM
Jarods7920's Avatar
What do you mean depends on what route i decide to take?
Old Feb 12, 2008 | 09:27 AM
pmohr's Avatar
No more Maximas...
Full swap or retaining 3.0 timing components.
In any case, there are hundreds of threads on this, including a detailed sticky in AM.
Old Feb 12, 2008 | 10:48 AM
Jarods7920's Avatar
right right i have read that majority of them several times over these are just the questions i cant seem to find a definitive answer on. Some of them say different things or arent clear as to what is needed.
Old Feb 12, 2008 | 07:31 PM
NmexMAX's Avatar
dot dot dot ...
Which ECU are you planning on using?
If you use the VQ35 ECU, you will not need to use cam spacers. If you use the 4th gen ECU, you will need cam spacers.
Old Feb 13, 2008 | 12:37 AM
toyick's Avatar
yeah...if u use the cam spacers from what i under stand...u will be using the 3.0 timing assembly, thus getting rid of the vtech or what ever u want to call it in the vq35. that in hand makes it were u can use the 3.0 wiring harness and u pretty much just cut and splice the enjectors..and u run ur normal 3.0 ecu
thats what i have gotten from all the reading i have done anyways...and im awaiting my motor soon
Old Feb 13, 2008 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Please don't confuse VTEC with Nissan, please?
Old Feb 13, 2008 | 07:31 AM
Jarods7920's Avatar
i plan to run the 3.0 ECU thus the reasoning for me wanting the spacers from what i have read it is very dificult to run the 3.5 ecu it be DBW and the transponder and such.
Old Feb 13, 2008 | 10:36 AM
toyick's Avatar
oh ok im sorry....variable valve timing... almost the same idea as vtech..
Old Feb 13, 2008 | 10:40 AM
pmohr's Avatar
No more Maximas...
CVTC !=
Fbana41
Aug 29, 2016 12:18 PM
gustavison
Oct 4, 2015 06:50 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MaxRPM6
Sep 11, 2015 06:56 PM
