Airbag light codes
Airbag light codes
I wrote in on this subject earlier. After reviewing the symptoms with my sister (driver of 95 SE) she said the light didn't turn on until her car was jump started. So, there must have been an issue while that happened.
Pete, from the 3rd gen forum, gave me this procedure on extracting the airbag codes:
"99 Infiniti 3.0> Procedure to access SRS codes: 1) Open drivers door and turn on the ignition. 2) Use your hand to cycle the doorjamb interior light switch on/off 5 times in 5 seconds. 3) Read codes on the flashing SRS (airbag warning lamp) MIL. To clear codes: 1) Turn off ignition, wait 5 seconds then turn back on. 2) Cycle doorjamb switch 8 times in 5 seconds. 3) Turn off ignition and close the door."
I was wondering if there is a website posted that gives airbag codes for the 4th generation, or if someone could post them. If there are too many, I'll wait until I drive up there and extract the code. Thanks.
P.S.
I have the site for the check engine codes, but this is a different light
P.S.
sctludwig
09-01-2022 01:32 PM
Maxima30
09-07-2015 06:13 PM
