When changing a caliper is it totally necessary to bleed the system?
Just wondering if I should bleed the system when I change my caliper. Any input would be appreciated. Thanks in advance.
EVERY time you open any of the hydraulic lines anywhere in the brake system, you MUST bleed the system.
of course that doesn't mean simply pulling the cap of the MC to top off the fluid, but any time you open any other part of the system, you introduce air and moisture to the lines, and they must be bled for proper operation.
Please find and read a service manual, or search for brake job writeups on the forums. there's TONS of info out there.
Edit...
honestly.. based ont he questions I've seen here, I recommend you take the car to a professional. Saving money by doing it yourself is nice, but it's dangerous to work on brakes when you don't know what you're doing.
A few bucks to replace a caliper and bleed the brakes is much cheaper than even the ticket and insurance premiums you'll have to pay if you screw it up and wreck your car.
Edit...
If your going to do anything that Involves the calipers and the brake master cylinder and changing brakes to changing brake fluids and changing washers and opening the bleeder valves, Yes you will have to bleed the whole brake system.
