Removing ENTIRE Dashboard from vehicle.
Old Feb 27, 2008 | 08:10 PM
goldtooth's Avatar
Ok, I got the whole center console out, the guage cluster with bezel, the steering wheel top and bottom covers, the fuse cover at your knees. Now I dunno what to do next. If anyone wants to know, I'm taking out the entire dashboard so I can have easy access to the firewall as well as taking out the Dash harness for a full 3.5 swap. Thanks.
Old Feb 27, 2008 | 08:24 PM
MOHFpro90's Avatar
The glove box needs to come out. 2 screws at the bottom, 2 inside at the top, and 2 holding the latch. Then the A pillars need to come out, IIRC. After that, Im not sure.
By center console, you mean radio, a/c etc...?
Old Feb 27, 2008 | 08:36 PM
goldtooth's Avatar
A pillars are already out and I already have the whole center console out aka, radio/ac/pocket, and cupholder with armrest. I will do the glove box tomorrow.
Anything else?
Old Feb 27, 2008 | 08:53 PM
black_maxed95's Avatar
to take off the entire dash you need to pop out the side vents and the little vents above the vents that arent really vents...lol...there are screws behind those to take off the big main piece.
Old Feb 27, 2008 | 08:54 PM
its pretty self explanatory, just feel around for where it is held on tight and there should be a screw near by
Old Feb 27, 2008 | 09:02 PM
goldtooth's Avatar
ok, i will look at it tomorrow
Old Feb 27, 2008 | 09:07 PM
BiZzL3's Avatar
good luck...hope you dont crack anything..
Old Feb 27, 2008 | 09:43 PM
Luiz's Avatar
go to autozone and buy, or just take a look at the haynes guide, they have all the info u want, i`ll see if i can get my scaner runing tomorow and i`ll post pics of the diagram they have.
Old Feb 28, 2008 | 01:12 AM
ThurzNite's Avatar
There's a full writeup in here (and maybe with pictures, i don't remember). Search for replacing heater block.
Dr J
Old Feb 28, 2008 | 01:13 AM
ThurzNite's Avatar
Oops, I meant heater core
http://forums.maxima.org/showthread.php?t=380679
Dr J
Old Feb 28, 2008 | 06:50 AM
maximabebe's Avatar
Goldtooth, I believe you will need a a T-50 tamper-proof torx bit to remove 4 (or possibly 6) bolts underneath the dash. It's been a while since I have done it myself but I am almost positive it is a T-50 size. The bolts that I am referring to are up in front of where the driver's right knee & passenger's left knee would be positioned if seated in the vehicle.
Old Feb 28, 2008 | 07:05 AM
btbrown's Avatar
This link is from autozone with full details on removing the dash.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Feb 28, 2008 | 07:07 AM
ROCKART's Avatar
wants an I35
these are the same ones needed to remove the passenger airbag correct?
where do i get this bit?
autozone? my dealership?
i dont wanna spend a lot...
Old Feb 28, 2008 | 07:46 AM
Capital15's Avatar
Great info! I am getting ready to swap my "Dooky" Brown dash to a black one...this will make it easier.
Old Feb 28, 2008 | 06:54 PM
maximabebe's Avatar
I believe so....like I said, it has been a while.
I got my bits (12 pk. assorted sizes) from a no name tool shop in CT for $7.00. Never once failed me.
Old Mar 3, 2008 | 04:34 PM
goldtooth's Avatar
got some more done today, but then it got dark outside
Old Mar 3, 2008 | 04:36 PM
goldtooth's Avatar
the little vents that blow on the driver and passenger side window by the mirror area? or the front vents for people in the car?
I got the security T50 or T55, are you referring to the 6 tamper-proof T50 bolts that are holding the passenger side airbag? is there any more on the driver side?
I did all this today.
Old Mar 3, 2008 | 10:47 PM
eng92's Avatar
Why are you removing the entire dash to do the full 3.5 swap?
You certainly do not need to remove the original A32 main harness either.
Old Mar 3, 2008 | 11:00 PM
KRRZ350's Avatar
If it's the same size as the airbags, which I'm geussing it is, it's a T45
Old Mar 4, 2008 | 06:34 AM
oldngivout's Avatar
Willing to learn
Definitely a T-50, boss!
Old Mar 4, 2008 | 07:55 AM
goldtooth's Avatar
I want to get easy access to all the wiring, especially for the hack job alarm install someone did before me. Did you just cut off the connectors you needed from the 4th gen dash harness?
That's alright, I got many sizes.
Old Mar 4, 2008 | 08:44 AM
eng92's Avatar
I think you are getting your harnesses mixed up.
The only connectors I cut off of the A32 main harness were the three for the gauge cluster. I only did that because I swapped in the A33B cluster several months before I started the actual engine swap.
It is the A32 engine control harness that you will be cutting several connectors off of if you want your A33B main patch harness to be PnP.
Old Mar 4, 2008 | 01:42 PM
goldtooth's Avatar
Hmmm? wow, I don't know myself anymore...lol
I am going to be putting in a 6 spd guage cluster as well....
So, I don't have to touch the dash harness at all? I am going to be swapping the guage cluster though, is the wiring for swapping the cluster here?
http://forums.maxima.org/showpost.ph...64&postcount=9
Why does it say pruned main dash harness? I thought the engine harness is separate from the dash harness?
Old Mar 4, 2008 | 02:16 PM
eng92's Avatar
When referring to a specific harness, always specify whether it is from an A32, A33B or A34.
No, the cluster wiring is not part of the harness I have shown. For wiring the cluster, it is probably easier to do it the same way I did. Just cut off the three A32 cluster connectors and wire the A33B ones in.
The A33B engine harness will be left almost fully intact. That picture is what remains of the A33B main harness.
Old Mar 4, 2008 | 04:04 PM
goldtooth's Avatar
Do you remember if it is the same pin for pin? and are they the same colors? Should I take my time checking the FSMs ( )
Old Mar 11, 2008 | 11:59 PM
goldtooth's Avatar
bump for post 25
and I almost got the dash out, there is still something holding it at the top windshield vents?
my03maxima
Jul 28, 2024 07:40 AM
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
