throttle bodies
throttle bodies
hi i was wondering what size throttle body come in the vq30 and if there are other that you would recomend installing eater aftermarket or form a different car. and it possibe to have a throttle body that is to big??
thanks.
thanks.
The only one commonly used is the Pathfinder throttlebody from previous gen. Pathfinders that had the 3.5 (not the 3.3 or 3.0). Theoretically you could put just about anything on with the proper adapter plate, but even the Pathfinder one will net you nothing but throttle response on an NA Maxima, especially with the stock intake manifold.
http://forums.maxima.org/showthread.php?t=282056
http://forums.maxima.org/showthread.php?t=394508
http://forums.maxima.org/showthread.php?t=404001
BTW: http://forums.maxima.org/showthread.php?t=547220
Our stock throttlebody: ~62mm (outlet)
Pathfinder 3.5: 70mm
Q45: 90mm
its definitely possible too have too big of a TB. I used to have a 97 tbird with the 4.6 litre that I put a 70mm TB on, and I lost a good bit of my of bottom end power. and gained a little top end. with a smaller engine like the 3.0, stock would be best unless its boosted. 70mm is WAY too big for a 3 litre. an engine will only use as much air as it needs. a smaller opening speeds up air flow, too big and it slows down
what? no im not im sayin that. a 3.0 like that in the max, does not use as much air flow as a 70mm TB would allow. at least not in basically stock trim. maybe if you did some p&p, then it would be beneficial.
REDinLV
Aug 15, 2024 12:30 AM
220k+ A32
Sep 23, 2015 03:38 PM
And these days, it's getting to be nearly as cheap as what a Pathfinder throttlebody + an adapter plate would cost.
