CAI template
Old Mar 4, 2008 | 08:54 AM
Dave H.'s Avatar
CAI template
Hey people,
I bought a Ebay/Bomz CAI (this kit: http://cgi.ebay.com/ebaymotors/95-96...spagenameZWDVW). I found a cutting template on a cardomain site ( http://www.cardomain.com/ride/711695 bottom of page) and I was wondering it that template will work for the Bomz kit.
Has anyone used that template before for this kit? I know I could just guess where to cut, but I'd rather not.
Please do not post about CAI's and how good/bad they are. That is not what this is about.
Thanks,
David
Old Mar 4, 2008 | 09:07 AM
black_maxed95's Avatar
It looks good but my question is how would you print that out to its original, exact size. That cardomain picture is much smaller than the original page it was on.
Old Mar 4, 2008 | 09:15 AM
Dave H.'s Avatar
All I have to do is save it and then open it with a program, like Window picture and fax viewer and print to full page, I've actually already done it.
Old Mar 4, 2008 | 09:22 AM
Snypa's Avatar
that shud work.
Old Mar 4, 2008 | 11:56 AM
maximized98's Avatar
Addicted to the Org
Doesnt have to be perfect. There will be some play in the intake. Just get it close, and you will be fine.
Old Mar 4, 2008 | 12:07 PM
OnEBadAsSi30's Avatar
I have a Bomz CAI and I didn't use a template. I just mocked everything up and then saw where it was "suppose" to be then I took a 3 inch hole saw and a dremel to it to clean up the edges. I also painted it around with some black paint to make sure the metal wouldn't rust.
Old Mar 4, 2008 | 05:44 PM
Dave H.'s Avatar
Yes I know I could do that, but I want to know if anyone has used this template for the Bomz kit.
Old Mar 4, 2008 | 06:14 PM
CRiME's Avatar
oem ftw!
When I was using the Bomz CAI, I used that template and it worked. If I had to do it again I would just line it up, make a marking and drill the hole.
Old Mar 4, 2008 | 08:54 PM
Pyromaniac1050's Avatar
how good is the quality on that Bomz CAI? cant be the best for 30 bucks
Old Mar 4, 2008 | 09:00 PM
Dave H.'s Avatar
Use the free search feature...http://forums.maxima.org/search.php?do=process
But basically, it's good but needs a better quality filter.
Old Mar 4, 2008 | 09:02 PM
CRiME's Avatar
oem ftw!
No more about the quality please....only reply if you have experience about the topic (template being used for Bomz CAI). [/COLOR]
What more do you need to know? I just confirmed for you that the template works just fine with the Bomz CAI. The only problem I had was that I drilled the hole at night and it was kind of a pain to hold the paper down, mark the spot and drill the hole. I guess a better way to have done it would have been to cut out the diameter of the hole on the paper, lay the paper down, use a marker to mark the hole on the car, remove the paper and then drill it.
Old Mar 4, 2008 | 09:07 PM
Dave H.'s Avatar
Yes I know, I just don't want to turn this thread into another thread about CAI and whether or not they are beneficial.
Old Mar 4, 2008 | 09:10 PM
Dave H.'s Avatar
BTW- do you have any pictures of the install/finished product? I've seen other CAI's but I don't know if they are Bomz or not.
Old Mar 4, 2008 | 11:26 PM
maxstillen83's Avatar
why don't you buy something good like injen CAI or stillen cone works great or for better performance buy injen CAI & install stillen cone sounds & works great
Old Mar 5, 2008 | 08:56 AM
MOHFpro90's Avatar
Injec CAIs suck. Stillen Cones are WAY overpriced. Read before you post newbie, he already said that he does NOT want suggestions about what to buy.
Dave H, the BOMZ kit and most other ebay CAIs are exactly the same. So unless the person has a true Place Racing kit, then the pictures you see are exactly what yours is. Also, I think even the PR kit is the same.
Old Mar 5, 2008 | 03:07 PM
WhiteA32's Avatar
Yes I used that same template and I got my Intake from ebay, and it works out great. Just line up the holes and start drilling away!
Old Mar 5, 2008 | 04:06 PM
Dave H.'s Avatar
Thanks for that. I would've said something very similar.
Thanks for the info.
You've answered my question, thanks.
David
END THREAD
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
