Clutch problem
Old Mar 5, 2008 | 08:39 PM
stankonia's Avatar
StaNk On Ya!
Clutch problem
I just put a new clutch in and I"m now at 300 miles on it, but it has gotten very spongey and I almost have to push it all the way to the floor to switch gears....
Bled it two days ago and I'm back where i started..
What u guys think i should do next?
Old Mar 6, 2008 | 09:13 AM
pmohr's Avatar
No more Maximas...
Has the reservoir level gotten low? Find the leak, fix the leak, bleed the clutch system.
Problem solved.
Old Mar 6, 2008 | 02:38 PM
deadmax96's Avatar
hhrrmmm someone beat me to the same question...did a complete bleed, changed out both master and slave cylinder, replaced hydrolic line connecting to the tranny. However my problem is not "sponginess", I only have to engauge the clutch only a few centimeters before it grabs and i mean hard!! if i'm not on the throttle it stals. Stock OEM clutch, and flywheel. CAN someone help me try to find out what the problem is (would make my own post, but i didn't reach my reply to quota for the month) I am literally at my witss end here.
Old Mar 9, 2008 | 09:37 PM
ProDriver77's Avatar
Did you make sure to resurface or replace the flywheel before installing the new clutch disc and pressure plate? Also, did you replace the release (throw-out) bearing or use the same one from the old clutch?
Outside of an improperly surfaced flywheel or bad release bearing, the only other thing that can come to find might be a defective spring on the clutch not allowing proper alignment, which would cause a rough or "low" engagement such as you are experiencing.
Just my $.02 worth here from past experiences. I could be way off on this diagnosis, but it's worth a shot to look into.
-ProDriver77
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
