Bucking/hesitation between 30mph - 50mph
Old Mar 10, 2008 | 10:40 AM
Crusher47's Avatar
And the issues continue with my '99 Maxima.....noticed that cruising between 30mph - 50mph and trying to accellerate, the car will hesitate a little and buck, best way to describe it is the tranny doesn't know whether to stay in 2nd. gear or upshift to 3rd. Seems to happen mostly when slowing down from 60mph+ in top gear and the car downshifts, then trying to speed back up again.
Automatic transmission obviously. Any ideas? Thanks!
Old Mar 10, 2008 | 11:38 AM
Snypa's Avatar
coilpacks going im guessing....'99' afterall.
Old Mar 11, 2008 | 07:59 AM
Crusher47's Avatar
If it was the coilpacks, wouldn't it do it all the time, not just from decelleration, then accellerating again?
Old Mar 11, 2008 | 09:09 AM
urmab's Avatar
Well it could be your coil packs not all just one. There might be a torn boot on one of them, also it might be the actual unit. I would also recommend to check you injectors because they might be getting stuck either in the open or close position.
Old Mar 11, 2008 | 09:48 AM
Snypa's Avatar
and im assuming he has no codes.
Old Mar 17, 2008 | 06:40 AM
chrisZ's Avatar
My '96 did the same thing, it was the tranny. Had the tranny replaced, and all is well again.
Old Mar 17, 2008 | 07:23 AM
JtzMax's Avatar
Whatchyou say?
clean your TB and get a tranny flush and fill .... can't hurt, will probably help
Old Mar 17, 2008 | 09:15 AM
Divewjason's Avatar
It's probably a coil pack, especially if it's happening more while going uphill.
JtzMax's Avatar
Whatchyou say?
if no codes ... why is everyone saying coil pack?
Old Mar 17, 2008 | 09:20 AM
maxilac99's Avatar
i've done 3 of 6 on my 99 and when the last one was going bad it didn't throw a code until i noticed an obvious misfire..
Old Mar 17, 2008 | 09:57 AM
Divewjason's Avatar
After a while a coil pack tends to melt or to have holes appear on them. It doesn't have to throw a code to be a coil pack. Only when the coil pack gets bad enough does a code show up. Mine threw a code when the coil pack was actually beginning to melt.
Symptoms of a bad coil pack start out with misses while sitting in gear at a stop light.(The car shakes.) This will start to get worse as time goes on, then you will start to feel your car buck as you are going up a hill at about 40 mph or below.(This differs based on the severity of the wear and tear on a coil pack.) It goes beyond that if left intended, if you gun it eventually the SES/CEL light will start to flash on and off.(Indicating an obvious misfire.) If you wait long enough eventually the light will stay on and will throw a code based on which cylinder the faulty coil pack is located.
Hondarydr
Dec 30, 2024 06:15 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Bonka
Sep 14, 2015 11:18 PM
Craig Mack
Jun 8, 2002 10:35 AM
