Ticking noise
Old Apr 12, 2010 | 07:03 PM
  #41
hynes66's Avatar
I have the same ticking sound as udienow. If it is the tc tensioner would it damage the car to keep driving like that? I have to get it fixed soon... it's very loud and a little embarassing.
Old Apr 13, 2010 | 01:42 AM
  #42
v3rtex7740's Avatar
I have the exact same ticking noise on my '99. I was worried until I started listening to the noise of other 4th gens, and realized they ALL make that noise, every single one. That's just how our cars sound. If you don't like it, get an intake to drown it out.
Old Apr 15, 2010 | 05:39 PM
  #43
hynes66's Avatar
Seriously.. so I can't fix it? Damn. I do love the car but that ticking is annoying. Well if anybody thinks of anything I'm all ears LoL (all ears, that's why the ticking sound annoys me so much)
Old Jun 4, 2010 | 09:07 PM
  #44
organ donor's Avatar
I had the same ticking noise as the video near the top. First check to see if you injectors are within factory spec's. then get seafoam(not the deep creep) and put little less than quarter of can in car through the intake method. then dump the rest( about 10oz) in to the gas tank when gas tank guage reads half full. Shake car side-to-side and bounce up and down to mix this with the fuel. then start car and go for a short drive, just enough to get gas with seafoam mixture into the engine. when you come back see if noise is still present. mine was gone
Old Jun 7, 2010 | 09:45 AM
  #45
Tyrguy4's Avatar
I'm having the same ticking noise from the right side of my rear head also..any fixes or idea's yet? I tried the sea foam and no improvement in noise.
Old Jun 8, 2010 | 07:17 PM
  #46
iDuty's Avatar
Originally Posted by DrPaulFlammond
Not to veer a little off topic, but I thought it was a solid shim/bucket setup? At least that's what I gleaned from all the reading the past week(s). The shims are used to set the proper clearance and it's all solid so the only reason for "adjustment" would be shim wear. This would require replacement of the worn shim(s) to reset the clearance to proper. Nissan basically has an array of various thickness shims to properly set this. <snip>
-DPF
DPF is right. No hydraulic lifters in the VQ30.
Old Jun 9, 2010 | 09:16 AM
  #47
when you say right side you mean the passenger side right? if so check the TC chain and tensior components
Old Jun 9, 2010 | 11:25 AM
  #48
cashoit's Avatar
Valve tick is audible but It shouldnt be loud. If your car is as loud as a helicopter then yes u have a problem.
Here is the problem that sucks. From what i hear the updated tensioner will reguire changing the chain guides and this is not an easy fix. Nissan no longer sells the 95-96 version. All u can try to do is find another used tensioner or try to fix urs. Do a SEARCH, someone jus replace the tensioner for a 95 and thats what he reported back.
Old Jun 10, 2010 | 10:36 PM
  #49
If nissan doesn't carry it, its not the end. go for aftermarket. not always best option but its better than doing nothing
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
