The start of my E-Manage Ultimate project
damn huh i wonder why when i use duration it doesnt work... :'(
the reason i wanted to use duration was simply because of the fact that dan (dandymax) says it easier/more accurate to use durations over duty cycle (especially when it comes to raising the rev limit). but if i cant get this figured out i will just have to use duty cycle
to answer your question no i havent played with extending the limiter, or any other features because i wanted to be my A/F ratio good first.
And maximaspd85, if you have a WB o2 then you can tune yourself, if not then you will obviously need to use a dyno and hook up their WB to tune
hmm what do u mean? you were using DC and are going to switch to duration? btw even thouh you are running rich with the dek injectors, i wouldnt screw around with the fuel maps too much yet just to be safe, untill you hook up the WB
before tune
After auto tune
as you can see before i tuned i was running pig rich 11.0:1 and even at times i would be running 10.5:1. just from the auto tune i pretty much am at 13.2-13.5 but when i go up higher rpms i will run about 12.1-12.6 so there is deffently some minor adjustments. but after all this i am very pleased with the outcome.
I did have some issues with running the auto tune. My first problem was that i didnt have the water temp wire hooked up to my ecu. then i hooked that up and i started overheating!! that scared me but then i read the jumper settings on the write up and jumper 13 i belive is suppose to be open so the fans turn on. So after all that it still wouldnt auto tune so i switch to duty cycle intead of duration and it worked. but i also put in my injector sizes cause it asks for injector size before and after(ie i put 259cc old de to 290cc dek) so i dont know if it was that that did it or changing the inj from duration to duty cycle. i learn more as i play with it more. maybe someone can chime in and clairify what is going on with my tune cough cough dandymax cough cough
After auto tune
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
Oct 24, 2015 08:05 AM
