ATTN: Anyone with Sprint Springs...Do I Need Camber Plates/Bolts?
Old Oct 30, 2001 | 12:45 PM
Nick97SE's Avatar
Getting ready to lower my car soon with Sprint Springs. They are a 2" drop. Just wondering if you guys would recommend camber plates or bolts or can I do without them?
Thanks!
-Nick
Old Oct 30, 2001 | 12:55 PM
Chebosto's Avatar
RIceD OuT moDErAtor
none needed.. there is enough play in the front struts to negate the offcamber.
==cheston==
Old Oct 30, 2001 | 12:58 PM
Nick97SE's Avatar
Cool! Thanks!
-Nick
Old Oct 30, 2001 | 01:13 PM
Sprint's Avatar
i got camber bolts
Old Oct 30, 2001 | 01:15 PM
BSwithTF's Avatar
They couldn't get mine aligned.
==cheston==
What's up with that? It was just out enough to wear the tires on the inner edge. Sears put some camber bolts in I haven't noticed any wear on my new tires.
Old Oct 30, 2001 | 02:04 PM
mzmtg's Avatar
Minister of Silly Walks
I have Sprints. I didnt need camber bolts.
Old Oct 30, 2001 | 02:44 PM
SuDZ's Avatar
How do you know if you need them?
SuDZ
Old Oct 30, 2001 | 02:49 PM
Jeff92se's Avatar
I'm needing a caw
After you get the alignment checked/adjusted, if the camber is now out of spec and can't be jiggled around to get back into spec(no offical factory adjustments), you will either need camber bolts(for small adjustments) or camber plates for larger adjustments. Camber bolts only have maybe 1 deg total adjustment or something like that(ie.. -0.5 to +0.5)
SuDZ
Old Oct 30, 2001 | 06:03 PM
Nick97SE's Avatar
I'm guessing by the replies that all cars are different. Some need 'em...some don't. I guess I'll find out whether or not I need them when I lower the car.
Thanks for the help!
-Nick
Old Oct 30, 2001 | 06:44 PM
sp6040's Avatar
sprints
i also have a 97 se with sprints i didnt need the chamber kit.just a little confidence builder.
Old Oct 30, 2001 | 10:33 PM
black019's Avatar
nope. dont need any.
Old Oct 30, 2001 | 11:37 PM
EdwardCYH's Avatar
-Nick
There is never a "must" for anything! Do you really need to get alignment after the installation? You are not "required" to. It's recommended to get it because your alignment is out of wack.
Same thing with the camber bolts/plates. Do you really need it? Nope. Are you willing to spend the money later on a set of tire because of un-even wear, or are you willing to pay the money up front so that your tires can last you couple thousand extra miles? It's all up to YOU.
Just a personal note, if you compare the cost of camber bolts and the cost of tires, I would buy the camber bolts....
Old Oct 31, 2001 | 02:18 AM
black019's Avatar
thats all true, but buying camber bolts implies that they are needed. if they arent needed, why get them?
Old Oct 31, 2001 | 02:46 AM
EdwardCYH's Avatar
I like your point, but now...
Buying 17 inch wheels implies that they are needed. If they aren't needed (who REALLY needs 17" wheels to get from point A to point B?), why get them?
Buying Sprint springs implies that they are needed. If they aren't needed (who REALLY needs to hug the ground when they drive?), why get them?
Getting the bolts/plates simply prolongs the life of your tires, and, for those perfectionists out there, that's doing it "right..."
Old Oct 31, 2001 | 03:01 AM
black019's Avatar
ok so your point was made nicely, but
nice 17" rims get you the females
nice looking drop gets you the females
camber plate/bolts gets you...
see they just dont fit in
see
Old Oct 31, 2001 | 03:08 AM
EdwardCYH's Avatar
see
Excellent points! I guess, because I am married, I don't quite think about the "female" factor!
Old Oct 31, 2001 | 10:38 AM
black019's Avatar
you're married? im sorry....
Old Oct 31, 2001 | 10:45 AM
pawn's Avatar
see
hmmm.......18's........bigger drop...i think im at an advantage...
Old Oct 31, 2001 | 01:06 PM
SuDZ's Avatar
Go get em tiger.
SuDZ
Old Oct 31, 2001 | 07:10 PM
MYSTICALKONCEPT's Avatar
you can grind some of the hole away and get yourself more adjustment on alinment i own alignment rack and we got it done cheap and easy with no problems i have coilovers and it will work
Old Oct 31, 2001 | 07:30 PM
pawn's Avatar
what?????
Old Oct 31, 2001 | 10:39 PM
black019's Avatar
wtf are you talkin about?
Old Nov 1, 2001 | 08:00 AM
EdwardCYH's Avatar
I know he said something about "grinding" some "hole"...
Old Nov 1, 2001 | 10:41 AM
black019's Avatar
whoa i aint into that freaky ish!
matts95max
Apr 23, 2025 10:44 AM
AKAICEBERG
Jan 30, 2001 05:41 PM
ejj
Jan 25, 2001 05:41 PM
AznStevie
Dec 18, 2000 08:07 AM
Slickismax
Dec 5, 2000 06:46 PM
