stupid car still choking
Old Mar 19, 2008 | 04:58 PM
93altima's Avatar
Turbo 4th Gen
ok so far ive been through:
4-MaF
1 coolant Temp Sensors
3 TPS Sensors
1 Knock Sensor
New Plugs
New Fuel Filter
and theres no check engine light like wtf its throwing no codes iam getting unpaitiant and the funny thing is i did the speed sensor mod (when you cant go over 118mph you cut the pink wire) and i still didnt trow a code i unpluged the IAT sensor while it was running then the CEL came on i cleared it and nothing elsee came up yet the car chokes if i press the gas too fast or when i reach about 4k rpms. when iam just at idle and press the gas it shoots up to about 6k then comes down by itself while iam still flooring it WHAT CAN IT BE ?????? PLEASE HELP if this doesnt get fixed soon iam sorry to say imma sell it and iam not gonna buy another one
Old Mar 19, 2008 | 05:31 PM
Snypa's Avatar
have you tried searching this prob on the org.(maybe stickies)?
Old Mar 19, 2008 | 07:57 PM
93altima's Avatar
Turbo 4th Gen
that was the first thing i did and i just tried another MaF out of My boys Max and its still choking
Old Mar 19, 2008 | 08:22 PM
mastere954's Avatar
i had a similar problem and it ended up being my crank pos sensor
Old Mar 19, 2008 | 09:38 PM
93altima's Avatar
Turbo 4th Gen
imma try this but any other suggestions???
Old Mar 19, 2008 | 10:15 PM
Maxima_Joe's Avatar
4th Gen Parts King
sounds like an intake leak.
Old Mar 19, 2008 | 10:24 PM
93altima's Avatar
Turbo 4th Gen
i checked the whole factory intake no rips
Old Mar 19, 2008 | 10:46 PM
Snypa's Avatar
check the cps like mastere said.
Old Mar 20, 2008 | 07:28 AM
maximase86's Avatar
I love lamp.
How is your vaccuum and idle? If good, I agree CPS would be the next stop.
Old Mar 20, 2008 | 03:06 PM
93altima's Avatar
Turbo 4th Gen
i checked both crank sensor and cam sensor and they're reading correct volts or ohms i took my boys 97 pcm and hooked it up it still did the same when i hooked my pcm back up P1320 came up ignition signal primary circut fault or misfire WTF IS THAT???
Old Mar 20, 2008 | 03:35 PM
VQrebuild96's Avatar
Well it can only be so many things don't get fustrated it could be worse... are you loosing coolant? I dont think thats your problem but its a posibilty. Check your fuel pressor. Go to autozone get a compression tester and fuel pressor tester. Then check to see if your getting the right spark it might be the coil packs... even injectors.
Old Mar 20, 2008 | 07:20 PM
93altima's Avatar
Turbo 4th Gen
iam not losing coolant and i will do that tomorrow but it is frustrating trust me you can imagine how do i test the coils??????
Old Mar 21, 2008 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...12&postcount=2
Old Mar 21, 2008 | 10:15 AM
93altima's Avatar
Turbo 4th Gen
well it was the coil and it was running perfect but then something happened idk but now the motor is blown
Old Mar 21, 2008 | 10:21 AM
NmexMAX's Avatar
dot dot dot ...
the motor is blown
How do you know that?
Old Mar 21, 2008 | 11:04 AM
93altima's Avatar
Turbo 4th Gen
the motor might not be blown but something in the timing area is cause i got off the highway every time i accelerated i hear the noise and it cuts off when ever i come to a stop
Old Mar 21, 2008 | 11:11 AM
NmexMAX's Avatar
dot dot dot ...
Any CEL's? Stop, take a step back, and diagnose it before flushing it down the toilet.
Old Mar 21, 2008 | 11:57 AM
What noise do you hear clicking? To me it does not sound like a blown motor. Maybe your ecu decided just to not work??? I dunno but i can tell you don't give up. It's times like this where u just hit the bong, relax and think about it in a diffrent way.
Old Mar 21, 2008 | 01:29 PM
93altima's Avatar
Turbo 4th Gen
no the noise is coming from the timing case i think a timing componet went i was doing about 100 on the highway against a integra and after awhile it wouldnt acceralerate no more i slowed down to my exit and the car just shut off at the toll both it started after a few cranks but i can hear the chain rattleing from inside the car as i took off i am afraid i bent a valve or something
Old Mar 21, 2008 | 04:33 PM
WOW this is why you don't race when your car has issues!! who won? Well it looks like you have a BIGGER problem now so i don't know if any one or even yourself can do anything about it, besides getting it repaired or a motor swap? Well good luck, peeece.
Old Mar 21, 2008 | 05:53 PM
93altima's Avatar
Turbo 4th Gen
yea ive decided to do a 3.5 swap
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
