starter on the way out?
Old Mar 19, 2008 | 09:03 PM
watut's Avatar
When I go to start the car sometimes, when I turn the key, it makes that noise like the starter is gone and she doesnt start. Then if i take out the key and turn it back on it starts first crank. Is this a sign my starter is on its way out?
Old Mar 19, 2008 | 09:15 PM
maximase86's Avatar
I love lamp.
Can you describe the noise? It could be the starter is fine, but you could be hitting a weak/bad point on the flywheel, but need a better idea of what you mean by noise like the starter is gone.
S
Old Mar 19, 2008 | 09:28 PM
watut's Avatar
S
You know that noise when you're trying to crank and your starter is dead and you get that noise thats like a screech
Old Mar 19, 2008 | 10:12 PM
shadyonedeath's Avatar
tried taking it apart and cleaning it?
they tend to get gunky...
Old Mar 19, 2008 | 10:25 PM
jdmkuruma's Avatar
sounds like your starter is going bad.
GoldMax96's Avatar
doesnt sound like the starter...idk why it would just fire right up after you take it out and try it again.
Old Mar 19, 2008 | 10:44 PM
Snypa's Avatar
dont think its the starter going bad either,more and likely..yess...it could have sumin to do with the starter.alow someone to start the car while your in the hood and listen to make sure the "noise" you hear is coming from it.if it is indeed from there, do as a fellow orger said...clean it.......have you ever done work on start/changed it.?
Old Mar 20, 2008 | 06:01 AM
watut's Avatar
Ill try that, I only had the car since December.
Old Mar 20, 2008 | 07:18 AM
maximase86's Avatar
I love lamp.
A screeching noise like a bad bearing noise or a screeching noise like something isn't engaging properly noise?
S
Old Mar 20, 2008 | 07:54 AM
soccerplr19's Avatar
i have the same problem except it starts after screeching for like 4 seconds. 99% of the time it starts. it prob is the starter needs to be cleaned.
Old Mar 21, 2008 | 03:03 PM
triax37's Avatar
I had a similar screeching noise at startup but ultimately it started. Turns out the belts running to the (recently replaced) alternator were not tensioned property (too loose). Once they retightened the belts, I've had smooth, quiet starts.
Old Mar 21, 2008 | 03:42 PM
was it hard to tighten the belts? and did you do them yourself?
Old Mar 23, 2008 | 10:20 AM
triax37's Avatar
I paid my shop to tighten them - if you have the right specifications, and tools, I don't think it's that hard. It took them less than 30 minutes, so they charged me $40. I was just swamped with work/moving, so didn't have the mental capacity to look up the specs and borrow the tools, etc.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
