Fuel Inj Question
Old Mar 20, 2008 | 01:10 PM
tbergma1's Avatar
Fuel Inj Question
I pulled out the fuel injectors and broke the white plastic cap things off the ends of the fuel injectors. Does anybody know where i can get some new ones?
I think the purpose of these plastic caps is to keep the lower oring from slipping down.
I put them back in and 2 days later its running on 5 cylinders. I pull out the fuel injector on the cyl that is missing and the f-ing oring has slipped down and it starts pouring gas down into the cylinder. I push the oring back on and put it back in and works good for 2 days and it starts all over again.
Old Mar 20, 2008 | 04:31 PM
pmohr's Avatar
No more Maximas...
They're called pintle caps, and they are more so to help the injector itself, not the o-ring (IIRC). I just yanked a pintle cap off of an injector I have laying around, and the o-ring won't go past the ridge on the bottom of the injector (where the pintle cap attaches) without some force.
Did you lube up the o-rings before reinstalling the injectors? You can usually get the pintle caps in injector o-ring kits from an auto parts store.
Old Mar 20, 2008 | 10:22 PM
mowgli29's Avatar
Horizontally opposed.
Excuse my ignorance, but does a broken pintle cap even matter? I've used many injectors with broken pintle caps in previous maximas and I've had no problems with them. What purpose do they serve?
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
conansriver
Sep 11, 2015 10:26 AM
