How were David L tails made?
Old Mar 26, 2008 | 05:47 AM
cardana24's Avatar
Blown
I just bought some David L 95/96 red clears and the def. do not match the inner tails. It looks like the color has faded. So I want them to match. How did he make them? Is there a write up he did? Did he split them and paint the inside? If so what paint did he use? Any good information is appreciated.
Old Mar 26, 2008 | 06:40 AM
96blackmaxSE's Avatar
boost me.....
Testor's Candy Apple Red.
Its a paint used for model cars...you can buy it at a hobby store.
IIRC, They have to be opened up by baking them or usig a heat gun, then painting the inner lenses. I have never seen a write-up for this either.
Old Mar 26, 2008 | 06:41 AM
boost me.....
Its only 3 oz cans so they are like 3 inches tall.
Old Mar 26, 2008 | 07:22 AM
matty's Avatar
He used multiple coats as well until the color matched. Not sure how many though.
Are you sure you purchased true David L's ?? Ive had mine for over 6 years and they are still perfect.
-matt
Old Mar 26, 2008 | 07:59 AM
cardana24's Avatar
Blown
-matt
The guy that I got them from in the classifieds said they were original David L's, and he had purchased them from Mr****sSE (his screen name is something like that). They are TYC lights so they are the ones that started out clear. I have no reason to believe they were not made by David L. They just don't match the inners.
Old Mar 26, 2008 | 09:23 AM
boost me.....
Just open them and throw some coats on them.
Old Mar 26, 2008 | 09:24 AM
boost me.....
Make sure you spray in THIN layers or it will crack and look horrible. I'd do about 4 layers of thin candy to clear it up.
Old Mar 26, 2008 | 09:54 AM
cardana24's Avatar
Blown
do the tester paints come in spray cans? The only testor paints I know of come in little containers made for use with brushes.
Old Mar 26, 2008 | 10:08 AM
Maxima98SE's Avatar
Check out Wal-Mart; I know they have Model paints in where they keep the models. If not, I know I've seen some small spray can versions of paint in the Automotive area
http://www.testors.com/catalog_item.asp?itemNbr=1405
You can see all the paints that Testors makes in various OZ size cans, you can also order from the site.
Old Mar 26, 2008 | 10:09 AM
cardana24's Avatar
Blown
ok, the local hobby store has the spray in stock. What temp should I set the oven on? How long do they need to cook?
Old Mar 26, 2008 | 10:19 AM
MrDicks95SE's Avatar
Offset Is Everything.
the guy i bought em from told me they were DavidL's....
Old Mar 26, 2008 | 10:54 AM
kzoosho's Avatar
I use 220 to bake my tails open for about 10 mins. Everyone is different.
Old Mar 26, 2008 | 10:59 AM
cardana24's Avatar
Blown
do you agree they do not match the inners? Do you have any pictures of them on your car?
Old Mar 26, 2008 | 11:01 AM
kzoosho's Avatar
If you want you can send them to me for a led retro lol and i can paint them for ya .
Old Mar 26, 2008 | 11:04 AM
yes they were pretty badly matched.
to repaint them to make it match use the oven baking method. 225* for 10-15 minutes or until it comes apart. use Testors candy apple red paint with light coats until it matches. let dry, pop back in oven with same specs and put back together.
Old Mar 26, 2008 | 11:05 AM
now THAT would be one-off. LED 96/96 redclears.
Old Oct 4, 2008 | 04:31 PM
Charlieb's Avatar
any one selling all clears any david l's ?? my 95 is really in need of some
Old Oct 4, 2008 | 09:17 PM
maxpeed96plat.'s Avatar
I believe DavidL was a member that opened up all clears and turned them into red/clear tails then sold them. I have some all clears in my closet and no they never did match the factory clear part of the inners exactly. And if they were in use for a long time i could see how the sun would cause an even more drastic difference in the clear top.
Old Oct 5, 2008 | 08:34 AM
kzoosho's Avatar
I just did a set of 95/96 david l's too.
Old Oct 5, 2008 | 08:47 AM
RA030726's Avatar
I'm nutty for Nissans
David L's were opened up and painted from the inside. Im fairly certain he did not use candy apple red. I think he used Vans tail light spray. Stil, Testers should work fine.
Old Oct 6, 2008 | 07:16 AM
Coolsaber57's Avatar
lols at the 7month old thread, but yes, testors candy apple red WILL work. I recently made some custom red/clears from some altezzas and they turned out pretty good.
Old Aug 30, 2009 | 06:58 PM
ny96max's Avatar
David used Vans Red Taillight paint. I had a set of these from his first run making them. They were an exact color match to the stock pieces. And were painted on the inside, NOT the outside.
The testors does not match at all, they illuminate a pinkish color.
Old Aug 30, 2009 | 08:28 PM
Not really. 2 coats of the testors on the inside and they match fairly well
No pink here
Also...why bump this thread? And why do it when you don't even have a Maxima anymore?
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
