door alignment
Old Aug 30, 2009 | 03:59 PM
mistur_sleepyass's Avatar
door alignment
so long story short i messed my door up because my genius self decided to rock the car off the ramps after i had drained the oil out of the car to put it on a level surface to fill the oil and my driver side door hit the rail of the garage door and my door took all of the damage and i had to get a new one
well i got another door and it bolts up fine it's just a little misaligned vertically and is a little close to my fender so my question is what is the best way to correct this problem?
Old Aug 30, 2009 | 04:42 PM
pmohr's Avatar
No more Maximas...
...adjusting the door?
Old Aug 30, 2009 | 05:46 PM
the door i have on there now do not meet any of those clearances
is it safe for me to throw some washers behind the hinge and shim it back?
Old Aug 30, 2009 | 06:31 PM
maxfever1987's Avatar
if its an oem nissan door for a 95-99 maxima, they fit 100% without an modification needed, unless when you messed up your door you also probably messed up the treading which holds the door bolts. i have changed over 100 maxima doors and never had an issue, do you have a pic of how it looks?
Old Aug 30, 2009 | 06:58 PM
cobradb's Avatar
are you sure you didnt twist the door mount at the hinges,, its possible.. this sometimes happen using improper car lifting / jacking procedure
Old Aug 30, 2009 | 08:53 PM
i'll take some pictures tomorrow when i have some daylight
and the whole twisted door mount may have happened, i'm not sure though
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
