Speedometer not functioning - need help
Old Apr 3, 2008 | 09:26 PM
Nealoc187's Avatar
SLOW
Electronics are not my forte. My speedometer has quit working. I have swapped the speed sensor with two other known good speedo sensors, and tested them all, and they all check out as working.
I'm looking at the FSM (page EL-78 for the 95 max) but reading electrical diagrams is not my thing. I need help. What are M58, M50, F105, F102, etc? What is the next step in troubleshooting this?
Old Apr 3, 2008 | 09:31 PM
Olezhka's Avatar
Did you check the little connector that's by the starter, it might just be unplugged?
Old Apr 3, 2008 | 09:38 PM
Nealoc187's Avatar
SLOW
it's plugged in.
Old Apr 3, 2008 | 09:57 PM
hot_wax_tree's Avatar
maybe somthing is busted in the gauge mechanics
Old Apr 3, 2008 | 09:59 PM
jdmkuruma's Avatar
have you checked your grounds?
Old Apr 3, 2008 | 10:13 PM
Nealoc187's Avatar
SLOW
the ground for the speedo is shared by the fuel gauge, and the fuel gauge works fine, so it's good. it must just be a wiring discontinuity problem. time to start tracing those two wires. i realized after I posted this that the Ms and Fs are male and female connectors.
Old Apr 4, 2008 | 06:08 AM
fat_kid's Avatar
i had the same thing and had to replace the speedo cluster but before that it seemed like there was a lose wire and i would tap on the cluster and fixed it for the moment.
Old Apr 4, 2008 | 01:08 PM
DBear's Avatar
Sometimes tightening the screws on the back of the cluster helps. If not, you probably need a new cluster (or speedo).
Old Apr 4, 2008 | 02:08 PM
ThurzNite's Avatar
I tap my dash top to get it going again. It seems to rejuvenate above 40mph. So usually, I don't think about it till I get into 5th gear, then I start tapping the dash top if it hasn't already woken up.
I've replaced my sensors, did the continuity check, but nothing. I'm thinking it's the guage, but there's not much I can do besides replace it. If you could take it apart, you could easily roll back the odo, and I'm sure they wouldn't like it if you did that. Good luck and keep posting updates.
Dr J
Old Apr 4, 2008 | 02:14 PM
Nopike's Avatar
Pull the cluster and redo all the connections on the back,especially the one to the speedo.
Old Apr 4, 2008 | 02:16 PM
matty's Avatar
I know you just had your cluster out to install your I-MFD wideband and SM-Fluid Temp so you might have knocked something loose in the cluster somewhere. Just an idea.
Old Apr 4, 2008 | 04:58 PM
ThurzNite's Avatar
I tried the "take out the cluster and tighten every screw" and that worked for several months. I haven't gone back to try it again, I didn't enjoy taking it out. But I think you're onto something here.
Nealoc187: how many miles you got?
Dr J
Old Apr 4, 2008 | 05:16 PM
Snypa's Avatar
makesure everything is plugged in.Make Sure!!!!
Old Apr 4, 2008 | 06:23 PM
Nealoc187's Avatar
SLOW
Was just a wiring problem - had to be a break/short in the wire somewhere. I ran a new set of wires to it and it works fine now.
Old Apr 4, 2008 | 06:26 PM
khantalha+'s Avatar
yeah neal same thing happened to my cluster so i replaced it with another one just to find that it was just the speed sensor unplugged....
Old Apr 4, 2008 | 09:47 PM
nismology's Avatar
M denotes connectors belonging to the main (dash) harness and F denotes connectors belonging to the engine control harness. [for future reference]
Good that you got it figured out though.
Old Apr 5, 2008 | 12:56 AM
ThurzNite's Avatar
You just ran some continuity checks and found it? Last time I did that, everything was continuous.
Dr J
Old Apr 5, 2008 | 07:28 AM
Nealoc187's Avatar
SLOW
Dr J
yes. i put the front up on jack stands and started the car and put it in gear. unplugged the harness from the sensor and checked the voltage just to make sure the sensor was outputting the correct voltage, it was. then I checked the same wires behind my gauge cluster and there was no voltage, so I knew it had to just be a break in the circuit somewhere. I just ran two new wires to the speedo from the sensor and problem was solved.
gavin68
Sep 18, 2021 12:36 PM
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
