front speaker grilles
Old Apr 4, 2008 | 02:02 PM
96maximized's Avatar
enthusiast
Does anyone here know how to remove the speaker grilles from the front doors if at all possible? Mine got a little dirty this winter and I want to clean them.
Old Apr 4, 2008 | 03:13 PM
MAXIMAK99's Avatar
I think you have to remove the whole door panel.
Old Apr 4, 2008 | 03:22 PM
fat_kid's Avatar
+1
Old Apr 4, 2008 | 04:06 PM
99max2fast4u's Avatar
the whole door has to come off lol
Old Apr 4, 2008 | 04:08 PM
garyrr's Avatar
its been about a year since i had my door panel off but if i remeber correctly once you take the door panel off there are a few clips on the back keeping it in place. how do u plan to wash it cuz mine are pretty bad 2 and i have tried scrubbing it from the outside but no luck. i might take them off and power wash them once i finish the project im in the middle of
Old Apr 4, 2008 | 04:21 PM
SmileyFace's Avatar
2 screws on the bottom and the rest of the doors is on clips. also remove the door handle clip or whatever it is and then pull up, unclip the door light and windows switches and you will be able to see your speaker which is just screwed in with 4 bolts.
Old Apr 4, 2008 | 04:24 PM
fat_kid's Avatar
the ashtray thing in the door handle
Old Apr 4, 2008 | 04:28 PM
andrei3333's Avatar
What about the tweeters ?
Old Apr 4, 2008 | 07:12 PM
enthusiast
I panned on using a mild detergent and soft bristle brush
Old Apr 4, 2008 | 08:13 PM
JSMax's Avatar
Sold
what about them. that tweeter grill that you see is just that... a grill the actual tweeter is placed way back behind the door panel. it's mounted to a peice of metal that is bolted to the inner door skeleton.
no need to remove the tweeter grill if you are removing the door panel.
Old Apr 4, 2008 | 11:48 PM
travmaximas1998's Avatar
ya just pull the door panel off and its like 3 screws if i recall right to take it off
Old Apr 7, 2008 | 06:42 PM
robsst's Avatar
Speaker Grill
I just installed in a new pair of Alpine speakers in my 95. (The stock ones are crap)
Check the Haynes manual.
From memory...
1 Unscrew the two screws on the underside of the door.
2 Pop out the cover and remove the screw from the bottom of the inside door handle.
3 Remove the light cover and two screws from the door light.
4 Pry up and remove the window controls.
5 Pop off and remove the cover from the door latch.
6 From the bottom outside edge of the door, pop out the door panel, working your way around the whole door, disengaging the inside clips.
7 Once the whole panel is loose bring it up to unhook it from the window jam.
The speaker grill has a cloth piece attached to the back, so I wouldn't recommend power washing.
I tried cleaning mine when I removed the panel, and couldn't think of a good way to do it without trashing something.
Good Luck.
adamgalazka
Feb 5, 2023 08:24 AM
9aj9
Apr 5, 2020 12:11 AM
The Frye
Feb 3, 2019 08:34 AM
jfl330
Sep 4, 2015 01:44 PM
