plz help
plz help
okay well first ide like to say YES i have lookd all around the org b-4 posting this ......i have seen some simular post's but nothing exact so hear goes.......when my car is in "N" nothing wrong happens...idels FINE....but when im in gear or crusing at 20-30 MPH my car CHOKES or when i punch it..CHOKES....it allmost feels like it wants to stall but not quite that bad....my car like jerks when it chokes....mostly happens when im at a stop...i tryed new spark plugs and now it's just Worse...any idea's? (auto by the way)
Second:
Third: CEL? Most likely coils.
Fourth: See numbers 1 and 2 again.
First: http://forums.maxima.org/showthread.php?t=547220
Second:
Second:
Second:
Second:
From: [Summer: High Rock Lake, NC, USA] [Winter: Midway, NC, USA] [Current: St Bernard, LA]
I had this same problem almost a year ago, found out that my gas tank was plagued with water in it and also, the strainer on my fuel pump was completely covered with trash to the extent that I could hardly even get any fuel pressure at all. First, check your fuel filter, that is always a given. Second, check into your gas tank (but for heavens sake be careful of explosive fumes and disconnect the battery first!), the gas tank is very easy to get into in this car, simply remove the bottom part of the back seat (all you gotta do is pull 2 release latches), then there is a cover right in the middle with 3 bolts holding it on, remove that, then you got several screws to remove on a round plate, and presto, the inside of the gas tank! Check the strainer on the fuel pump for clutter and trash, and look for bubbles in the bottom of the tank (water), that could also be a problem!
Number 1, Thread titles like yours help no one.
Number 2, you can't get help if you can't make coherent sentences.
Number 3, it's most likely your coils.
riggy
08-06-2001 07:35 PM
madmax97
07-04-2001 10:10 PM
tunedup
03-09-2001 08:00 AM
