anyone with carfax please help me!?
Old Oct 31, 2001 | 07:51 PM
vteckilla's Avatar
I am buyin a 95 maxima se tommorow that has 95k miles
an a salvage title just want some more info on it please.
heres the vin #JN1CA21D0ST069993
THANKS IN ADVANCE
Old Nov 1, 2001 | 10:17 AM
Anachronism's Avatar
Here you go, it says potential rollback but it looks like it just might be a typo at some point. I hope you are getting a great deal because of the salvage title.
ALERT! Carfax search results confirm this 1995 Nissan Maxima (JN1CA21D0ST069993) DOES NOT qualify for the $5,000 Carfax Clean Title History Guarantee. By ordering this Carfax Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Section #: Section Name: Section Results:
Vehicle Specifications JN1CA21D0ST069993
1995 Nissan Maxima
Title Check Clean Title History NOT Guaranteed
Odometer Rollback Check POTENTIAL Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 9 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that have not been reported to Carfax.
How did Carfax analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JN1CA21D0ST069993
1995 Nissan Maxima
4D Sedan Mid-size car
3.0L V6 MFI DOHC 24V
Gasoline
Front-wheel Drive
Normal
Japan
ALERT! Carfax search results confirm this 1995 Nissan Maxima (JN1CA21D0ST069993) DOES NOT qualify for the $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's history to determine if any title documents were designated or marked with the following types of problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete Carfax Glossary.
ALERT! Carfax search results on this 1995 Nissan Maxima (JN1CA21D0ST069993) identify a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
CALCULATION: POTENTIAL ODOMETER ROLLBACK
On 12/17/1998 the odometer reading was reported as: 86,084 miles
On 01/31/1999 the odometer reading was reported as: 80,100 miles
This represents a mileage decrease of: 5,984 miles
NOTE: Information supplied to Carfax indicates the above odometer readings may not reflect this vehicle's actual mileage. Carfax depends on its sources to provide reliable information and works diligently to ensure the quality of its Reports. In this case, we recommend you contact the seller or a qualified mechanic to verify this vehicle's actual mileage.
GOOD NEWS! Carfax search results on this 1995 Nissan Maxima (JN1CA21D0ST069993) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
Carfax search results on this 1995 Nissan Maxima (JN1CA21D0ST069993) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The Carfax database contains a total of 9 vehicle history records on this 1995 Nissan Maxima (JN1CA21D0ST069993):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
12/01/1994 Colorado
Motor Vehicle Dept.
Pueblo, CO
Registered as private vehicle
12/15/1994 111 Colorado
Motor Vehicle Dept.
Pueblo, CO
Title #02M259059
Title or registration issued
First lien reported
12/17/1998 86,084 Colorado
Motor Vehicle Dept.
Littleton, CO
Title #47S100568
SALVAGE TITLE/CERTIFICATE ISSUED
12/17/1998 Colorado
Motor Vehicle Dept.
Littleton, CO
Title #47S100568
05/25/1999 83,082 California
Inspection Station
Van Nuys, CA
Passed emissions inspection
06/01/1999 80,100 California
Motor Vehicle Dept.
Odometer reading recorded on 01/31/1999
06/01/1999 California
Motor Vehicle Dept.
06/16/1999 California
Motor Vehicle Dept.
01/31/2001 95,346 California
Inspection Station
Comment Definitions
Odometer Rollback If a more recent odometer reading is less than an older reading, then the odometer may have been "rolled back."
Salvage/Junk Title States issue salvage titles when an insurance company takes possession of a vehicle as a result of a claim. This generally occurs after a vehicle has been declared a total loss. States issue junk titles to indicate that a vehicle is not road worthy and cannot be titled again in that state.
NOTES:
You have significantly reduced your risk of purchasing a vehicle with a hidden problem. However, Carfax has not inspected this vehicle. There could be other potential problems with this vehicle that have not been reported to Carfax.
Not all titles issued represent a change in vehicle ownership. For example, a title could be issued to reflect an address change or correction.
Carfax Disclaimer:
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
Customer Service: websupport@carfax.com
www.carfax.com
© 2001 Carfax Inc., an R.L. Polk & Co. All rights reserved.
01.Nov.2001 12:10:16
Old Nov 2, 2001 | 05:40 AM
vteckilla's Avatar
thanks a million,yeh I got the car today a 95 se model fully
loaded including digi climate control.its lowered with
h&r an tokicos an rides on the very expensive 17inch blitz
wheels.I will post pics soon.
Old Nov 2, 2001 | 10:44 AM
cooler2000's Avatar
i am curious why you bought this car if it had bad title?
Old Nov 2, 2001 | 10:48 AM
vteckilla's Avatar
it was a theft salvage an the guy had pics to prove it so
I had felt I had no worries also if it was an accident
salavage I woulnt have botherd with it,honestly this car is
cleaner them most new msximas I see it dosnt have one scratch
or door ding,has stillen kit an the hard to find pearl white
that I love.
John C.
Feb 23, 2002 04:03 PM
NYC GS4
Dec 4, 2001 11:11 PM
Anachronism
Oct 1, 2001 01:56 PM
