A decade old; time for new suspension!
Old Apr 14, 2008 | 07:55 AM
Tight_Whip's Avatar
I need suggestions on some good Shocks & springs for my Maxima. It's definatly time to replace my old ones, my ride bounces over every bump in the road. I don't want to lower my Maxima too much (for reasons of: I don't want to hit/scrape everycurb).
Also, I have to replace the air filter for my PlaceRacing CAI, and I don't know the dimensions. Can anyone help plz. I think its 2.5inch but i'm not sure.
http://cgi.ebay.com/ebaymotors/TOKIC...spagenameZWDVW
Tell me if these are any good. this is a link to some suspension on ebay
Plz help, I plan on doing so soon.
Old Apr 14, 2008 | 08:58 AM
VANGtastic97's Avatar
hey I'm actually going to help you out before you get flammed. That setup is decent (from what I read), but those shocks/struts are basically just stock replacements.
I suggest buying those same shocks/struts, but from a member in the classifieds section who's looking for 300+shipping. He's been wanting them sold for a while so I'm sure you could offer a little less. http://forums.maxima.org/showthread.php?t=550269
Then, if you wanted a bigger drop, you could buy the progress lowering springs in the Group Deals section for only $157 shipped. The drop on those is 1.7F and 1.5R. This is probably the lowest you want to go with those OE replacement shocks/struts. Unless you want to step it up to the Tokico Illumina's, then you would be fine.
Lastly, you will need to buy some other things like the bumpstops/boots, mounts, bushings...search
Old Apr 14, 2008 | 07:12 PM
Maxie40's Avatar
Max40
I am replacing my suspension
I am also finally replacing my struts/springs on my 1995 Maxima which I actually bought brand spanking new in 1994. My maxima didn't bounce but did give me a very stiff ride. I replaced the rears but my car's backend is moving all over the place when I hit a big bump. Doing the fronts this week I hope I get the original ride back, it was sweet!
Old Apr 17, 2008 | 10:00 AM
Snypa's Avatar
Why would he get flamed.? Isnt this the place to get help.? Simply get stock struts and springs if you like the setup that you have now.
Old Apr 17, 2008 | 11:37 AM
bigpulve+'s Avatar
Because this is a subject that has been covered in countless threads dating back to 1999...that and search is now free so everyone needs to use it....Oh and its also in the stickies...
Old Apr 17, 2008 | 06:12 PM
Tight_Whip's Avatar
I tried finding out about what I asked; I wanted opinions. But sense you're such a guru, why dont you link me buddy?
Old Apr 17, 2008 | 06:36 PM
maxim82's Avatar
go with H&R springs and illumina shocks i got mines installed and it looks and rides great
Old Apr 18, 2008 | 09:02 AM
Tight_Whip's Avatar
Do you have any pictures? Also, a buddy of mine was telling me that any time you lower a car you need to emplace a camber kit. This is so, because he said "it will wear out your tires faster," do to the fact that when you lower the car the camber angle changes forcing more weight on etheir side of the tire(depending on angle).
Old Apr 18, 2008 | 09:14 AM
3 point slow's Avatar
Somebody chime in if Im wrong but if youre just doing a mild drop, (I suggest the h&r springs and tokico shocks setup), youll just need a good 4 wheel alignment. Dont forget to get new mounts, too. You COULD go stock but in my opinion, your car will look SOOOOO much better without that 4x4 wheelgap you got going on. Plus, handling is greatly improved. Wont scrape, either. Just take real tall speed bumps nice n slow.
bigpulve+'s Avatar
Well from what you wanted you should just stay stock. Tokico blues, which are stock replacements, and your OEM springs is what you are looking from. Every after market spring is going to lower you car at least an inch. Also I didnt see any mention of wanting more handling ability or ride quality.
Picking an after market suspension is all up to your wants and needs. We can give you all the info but its still your ultimate decision. That is what I was meaning with using the search engine. You can find and see how each different setup affects other variables, thus giving you a better understanding and ability to pick a proper set up.
Old Apr 18, 2008 | 09:16 AM
bigpulve+'s Avatar
We cant get a 4 wheel alignment. We dont have IRS.
Old Apr 18, 2008 | 09:20 AM
Oops. Thanks for the correction. Then, just an alignment. Prolly a good idea when replacing major suspension components, anyway.
Old Apr 18, 2008 | 09:23 AM
bigpulve+'s Avatar
I also forgot to mention anything about your PR CAI...It isnt worth cutting a 3in hole in your fender wall...Nissan did a very good job in designing the 4th gens air intake...It really is the best intake for our cars...
Old Apr 18, 2008 | 09:28 AM
MOHFpro90's Avatar
Behind a snail.
Eibach springs are always an option if you dont want to drop much.
Tight_Whip's Avatar
Oh, I put the PR CAI a long time ago(i just needed the dimensions for the replacement air filter; which I now have and already bought though)... Hehe, thanks though.
Old Apr 18, 2008 | 09:30 AM
bigpulve+'s Avatar
Originally Posted by MOHFpro90
Behind a snail.
I need a new midpipe...I threw mine away...
Old Apr 18, 2008 | 09:32 AM
SNOMAX's Avatar
PM me for LCA's!
Since you are looking for opinioons, here is mine: you have 2 ways to do this:
1) you can go stock replacement, but really you want to get the Tokico illuminatas. The package that is sold on e-bay gos for about $500 shipped and is springs and 5 way adjustable struts. Then you can get an alignment--but expect to only get as close an 1 degree of negative camber. This will not significantly impact your tire wear.
If you decide to do anything else... get coilovers (see #2 below)
2) Coilovers. here you can adjust you drop, usually as much as 4" and you can usually adjust camber. If you go for option #1 above and add camber plates, you might as well buy coilovers. you can find them for $800 new or much less new.
option 2 may sound like a lot, but if you go for Illuminata ($500) and add camber plates ($250+) and then have to buy new Top portions of th strut ($150 at least) you can see where you are already at the price of a coilover.
I don't think Tokico Blues are worth it. unless you struts are blown and you are looking for a stock replacement, use them as simply a cheaper alternative to OEM.
Now, after you drop your Maxima remember to align it. Some say 4 wheel tohers say we cant 4 wheel. What you really want is to find a shop that does race cars and ask for... are you listening?? Ask for a 4 wheel thrust angle alignment AND (did you see the AND) re-center your rear beam.
Let me explain. When you drop your rear suspension, the lateral link is at an angle ans the suspension will be off-center about 1/2" for every 3" of drop. To really get everything tracking correctly, you need this.
My opinion for you is option1.
Old Apr 18, 2008 | 09:41 AM
Tight_Whip's Avatar
That was some really good advice! I have just one question now. Do you think the springs that come with that Tokico kit (1.5/1.25) is enough to get rid of my huge gap front and rear?
Old Apr 18, 2008 | 10:22 AM
bigpulve+'s Avatar
its not going to get rid of it...I have K sports at a 2in drop and I still have wheel gap...
But it will lessen it to where it isnt as noticeable to the regular person..
Old Apr 18, 2008 | 04:39 PM
MaxGordon7's Avatar
Cheap and simple way to give you a little less wheel gap and a little better handling. You will still have a lose *** end with this set up in the turns. If you want a low wheel gap it is not going to make you happy. Progressive(cattman) spring cars look great to me on that.
An alignment is always good to check. I put S.tech(2.2/1.8) and my car was still in factory spec when i had my checked out. Put it to the fact I got it when she had 28k miles and I never put her over a curb.
Old Apr 18, 2008 | 06:52 PM
Whatever you do, do not put Tein S-techs on your max. You're just going to have more problems than you do now in a few thousand miles.
Old Apr 18, 2008 | 07:13 PM
Maxie40's Avatar
Max40
Suspension gap
OK just finished the fronts with stock OEM struts and springs SE. I now have noticebale wheel gap in the front but when I did the rears it seemed to stay the same. Now I have heard the suspension "settles after a few thousand miles" and the car should balance out to that original stock look. Is this true?
I am learning this forum which seems like a tough crowd for etiquette but I'm just an old guy looking for advice for a car that keeps me happy!
Old Apr 18, 2008 | 07:29 PM
bigpulve+'s Avatar
Ok, do you have an SE or did you just put SE springs on a non SE? Also is their anything in your trunk? It should be completely even...
Old Apr 20, 2008 | 11:42 AM
Tight_Whip's Avatar
Any opinions on progress springs with Tokico Struts?
Old Apr 20, 2008 | 07:05 PM
Maxie40's Avatar
Max40
I only put SE parts on my SE. Trunk has some stuff in it but not enough to see the slight rise in the front.
Old Apr 21, 2008 | 05:08 PM
bigpulve+'s Avatar
Originally Posted by blumax1023
i HAVE K-SPORTS ILL SELL YOU FOR 500....THERE BASICALLY BRAND NEW...VERY NICE
ALSO....TWO OF THEM HAVE NEVER BEEN USED!
Take off the caps lock holmes.
Matt93SE
May 24, 2019 02:58 PM
Chef N
Sep 22, 2015 11:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
laparka66
Aug 6, 2015 09:36 AM
