PR CAI K&N filter question
I cannot find the specs (Dimensions) anywhere. I have the PR CAI and I need to replace the Filter. Can someone tell me if the type of K&N filter I selected is correct or the dimensions. The address to the one I think is correct is below. Thanks.
http://www.knfilters.com/search/prod...x?Prod=RC-0790
The filter you linked to is way too small. I went with RE-0930 and it works great. You can search on K&N's site by measurements. http://www.knfilters.com/search/univ2.aspx?ID=S0013
You should want a 3" flange inside diameter and about 6" in height.
I searched maxima.org and found RE-0930 was used by a few other people, so I went with that after I found the specs on that filter.
Well, go measure the piping on the intake. I'm pretty sure it will be 3" in diameter, like mine. So you need a 3" inside flange diameter.
And my CAI is pretty much the same as yours, but you probably paid more for it because of the name "Place Racing". It's an ebay CAI, but the same as Place Racing.
Place Racing means nothing when it comes to the K&N filter size. I remember at one point Place Racing was using Typhoon filters. You can basically put on any filter that fits. I talked to a K&N rep a few days ago and he told me the model number of the filter is somewhere on the black rubber. You just have to look around for it. Otherwise, measure the dimensions of the filter and call K&N to have the person on the phone find the filter for you.
http://www.knfilters.com/search/univcone.aspx
Anything with a 3 inch Flange Inside Dia. (F) will work. The height is up to u. Id go with a rubber 6 inch tall one.
http://forums.maxima.org/showthread....hlight=ru-2820
http://www.knfilters.com/search/prod...x?Prod=RU-2820
Was going to buy that when I had the PRCAI setup, but decided to go back to stock (somewhat )
JoshG
51
09-21-2015 10:41 PM
aminus21
09-12-2015 04:53 PM
sdotcarter
09-02-2015 09:53 PM
