Clunk sounds while going over a bump
Old Apr 17, 2008 | 05:04 AM
hiren_patel_83's Avatar
Guys, I need help, I have 18's on my car and i've scuffed two of them really bad. Now every since that happened everytime i go over a bump or pot hold it makes this clunking noise.
It's weird to explain but I'm assuming my struts are going back?
PLEASE HELP!!! THANKS.
Old Apr 17, 2008 | 06:39 AM
Greeny's Avatar
¯\(°_o)/¯
Bad wheel bearing/s will make a clunking sound, along with bad tierod ends/ball joints/control arm bushings/strut mounts/etc.
If you haven't replaced any of these items recently, start with the cheapest item, then move on to the next.
Old Apr 17, 2008 | 07:06 AM
Kadantsev's Avatar
That's a pretty large ball park.
Could also be the struts themselves.
I had the same problem. Replaced tierods, ball joints, control arms, and bushings. Sound was a bit better, but it wasn't until I replaced the struts that the sound went away completely.
Does any one know what makes a squeeking sound when going over bumps?
Old Apr 17, 2008 | 07:32 AM
soccerplr19's Avatar
i have clunkin clicking and all those noises, my mech told me my suspensions bad i just bought springs and struts, goin to replace those this weekend hopefully the noise goes away, its most likely struts, there prob bad
Old Apr 17, 2008 | 09:42 AM
Snypa's Avatar
check your boots and axles.
Old Apr 17, 2008 | 11:54 AM
my boots were replaced recently, but the sound comes from rear passenger side tire.
Old Apr 17, 2008 | 11:55 AM
ok cool, well let me know if you get new springs and struts if thats what it is i'll replace them as well.
Old Apr 17, 2008 | 12:49 PM
MAXIMAK99's Avatar
I have the same sqeaking sound you're asking about. I hear it every now and then. Mostly when going over bumps like you said. I have not been able to find the source. I replaced struts, springs, strut mounts, rack bushing, rotors, and brake pads, and I still have that squeak.
Old Apr 17, 2008 | 01:02 PM
Kadantsev's Avatar
That sux...
What the hell is it then?? It's definitely coming from the suspension assembly.
Old Apr 17, 2008 | 06:01 PM
knight71's Avatar
Could possibly only be your sway bar end link bushings..if it is, you're in luck, cos it's cheap and easy to fix. sway bar link kit is sold as a set and can be found at any automotive parts store.
Old Apr 30, 2008 | 10:51 AM
mark_jb's Avatar
Check your exhaust right before where the y-pipe bolts onto the cat. Mine did the same thing and I looked at it one day and the pipe was loose. I could push it and it would bump the under body of the car, making the same knocking sound I heard going over bumps.
Old Apr 30, 2008 | 11:07 AM
maximabebe's Avatar
Stick your fingers into the caliper (when it is cool obviously) to see if the pad is rattling around. I have the same problem right now due to the lack of shims which are en route from Nissan.
Old Apr 30, 2008 | 11:21 AM
97maximany's Avatar
Had the same problem ,when I change the rear strut I didnt change the top rubber mount(don't ask). I changed and all better
Old Apr 30, 2008 | 11:27 AM
okay i replaced the springs and struts and its alot better, but turned out i was missing a strut bearing one of my struts which was causing the clicking and clacking but that was mostly when i was turning
Mahmuth
Aug 16, 2024 08:23 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
